3.2 & 3.3 Extensions Database 3.2 / 3.3Email List
Email List
Extension Name: Email List
Author: RMcGirr83 & dmzx special thanks to martin
Allows a board forum owner to download and save a list of emails of users on the forum.
- Short syntax code.
- Code cleanup.
- Drop support for 3.1.
- Update routing.yml
- Twig update
Update listener.php.
Update emaillist.php.
Update service.yml.
Added code for 3.2(icon)
Allow to choose based on groups, fix routing and other issues.
Email List v1.0.4
  2. Unzip the downloaded release, and change the name of the folder to `emaillist`.
  4. Copy the `emaillist` folder to `/ext/dmzx/` if done correctly, you'll have the main extension class at
    (your forum root)/ext/dmzx/emaillist /composer.json
  6. Look for `Email List` under the Disabled Extensions list, and click its `Enable` link.
Re: Email List
You can download the csv list and import it in to your own email account or board account as long has your allowed to import.
If you have more than one founder and dont want the others access then
/controller/emaillist.php
change
if ($this->user->data['user_type'] != USER_FOUNDER)
to
if ($this->user->data['user_id'] != '2')
2 being the real board founder
tried and tested make the auth section like this
// Founders only access
			trigger_error('NOT_AUTHORISED');
cristian
    Windows XP Firefox
Re: Email List
Post by cristian »
Help me pliss
that may be the problem
most changed to
if ($this->user->data['user_id'] != ’2’)
Re: Email List
Are you the board owner ? pm me a link to your site
Edit it seems when you copy a line of code from this site this ' is being replaced
cristian
    Windows XP Firefox
Re: Email List
Post by cristian »
Yes I am the owner
I changed the code but I don't have access to the list
Re: Email List
See my first post pls
cristian
    Windows XP Firefox
Re: Email List
Post by cristian »
Now go thanks :beers:
Done!
romaamor
Re: Email List
Post by romaamor »
Good afternoon. What to do to get on the PC only list email ?
Re: Email List
:question: :question:
romaamor
Re: Email List
Post by romaamor »
Martin When I download CSV List, there is a lot to me too much information. I need that to a file that I had just save email.
Re: Email List
Download the file then upload it into your email account if your provider supports it that all you need to do.
romaamor
Re: Email List
Post by romaamor »
No. I need one address list.
Re: Email List
romaamor wrote:No. I need one address list.
:roll: just install it and click on the email list button.
romaamor
Re: Email List
Post by romaamor »
Do not you understand .... All that krastnym crossed I do not need.
I do not need the extra data.
Re: Email List
What are you doing ? you dont open the file you upload it or just used the ext for your own use of seeing emails.
I'm out of this topic i really cant be assed with some who really cant be bothered to read.
