3.1.x Extensions DatabaseLink menu
Link menu
Extension Name: Link menu
This extension will add a simple link menu to header and place the search box in navbar.
Link menu v1.0.0
  2. Unzip the downloaded release, and change the name of the folder to `linkmenu`.
  4. Copy the `linkmenu` folder to `/ext/dmzx/` if done correctly, you'll have the main extension class at (your forum root)/ext/dmzx/linkmenu/composer.json
  6. Look for `Link menu` under the Disabled Extensions list, and click its `Enable` link.
This topic has 5 replies
