3.1.x Extensions Database 3.1 / 3.2Topic Views
Topic Views
Extension Name: Topic Views
Displays Topic views in footer when viewing a topic.
Topic Views v1.0.0
  2. Unzip the downloaded release, and change the name of the folder to `topicviews`.
  4. Copy the `topicviews` folder to `/ext/dmzx/` if done correctly, you'll have the main extension class at (your forum root)/ext/dmzx/topicviews/composer.json
  6. Look for `Topic Views` under the Disabled Extensions list, and click its `Enable` link.
Taka51
    Windows Vista Firefox
Re: Topic Views
Post by Taka51 »
Here is the French translation for this extension
WebDvdBdR - Page d’index
Re: Topic Views
Taka51 wrote:Hi,
:thumbup: Thanks
Nuru
Re: Topic Views
Post by Nuru »
here is the German translation for this extension.
dmzy-Topic-Views translate german.zip
Re: Topic Views
Nuru wrote:Hello,
Thanks and added!
infspirit
Re: Topic Views
Post by infspirit »
Here is the spanish translation for this extension
Re: Topic Views
infspirit wrote:Hi,
Added thanks!
