Unzip the downloaded release, and change the name of the folder to `postauthor`.
In the `ext` directory of your phpBB board, create a new directory named `dmzx` (if it does not already exist).
Copy the `postauthor` folder to `/ext/dmzx/` if done correctly, you'll have the main extension class at (your forum root)/ext/dmzx/postauthor/composer.json
Look for `Post Author` under the Disabled Extensions list, and click its `Enable` link.
This extension requires at least phpBB version 3.1.4-RC1
networker007 wrote: 05 Jan 2021, 17:26
I install the phpBB (en additionally de) and check again, something is wrong on my fresh install with the ext post author...
so it look like without the ext post author / there is the correct ICON
and so it look like WITH the ext post author / the ICON is MISSING - i would like the icon back
I love this ext - how can I solve it? THX in advanced
phpBB encountered an error building the container due to an installed extension. For this reason, all extensions have been temporarily disabled. Please try purging your forum cache. All extensions will automatically be re-enabled once the container error is resolved. If this error continues, please visit phpBB.com for support.
Exception: The file "/home/ngigesig/public_html/ext/dmzx/usernamecolourchanger/config/services.yml" does not contain valid YAML: The reserved indicator "@" cannot start a plain scalar; you need to quote the scalar at line 5 (near "- @request").
#0 /home/ngigesig/public_html/vendor/symfony/dependency-injection/Loader/YamlFileLoader.php(117): Symfony\Component\DependencyInjection\Loader\YamlFileLoader->loadFile('/home/ngigesig/...')
#1 /home/ngigesig/public_html/phpbb/extension/di/extension_base.php(99): Symfony\Component\DependencyInjection\Loader\YamlFileLoader->load('services.yml')
#2 /home/ngigesig/public_html/phpbb/extension/di/extension_base.php(63): phpbb\extension\di\extension_base->load_services(Object(Symfony\Component\DependencyInjection\Compiler\MergeExtensionConfigurationContainerBuilder))
#3 /home/ngigesig/public_html/vendor/symfony/dependency-injection/Compiler/MergeExtensionConfigurationPass.php(71): phpbb\extension\di\extension_base->load(Array, Object(Symfony\Component\DependencyInjection\Compiler\MergeExtensionConfigurationContainerBuilder))
#4 /home/ngigesig/public_html/vendor/symfony/http-kernel/DependencyInjection/MergeExtensionConfigurationPass.php(39): Symfony\Component\DependencyInjection\Compiler\MergeExtensionConfigurationPass->process(Object(Symfony\Component\DependencyInjection\ContainerBuilder))
#5 /home/ngigesig/public_html/vendor/symfony/dependency-injection/Compiler/Compiler.php(140): Symfony\Component\HttpKernel\DependencyInjection\MergeExtensionConfigurationPass->process(Object(Symfony\Component\DependencyInjection\ContainerBuilder))
#6 /home/ngigesig/public_html/vendor/symfony/dependency-injection/ContainerBuilder.php(789): Symfony\Component\DependencyInjection\Compiler\Compiler->compile(Object(Symfony\Component\DependencyInjection\ContainerBuilder))
#7 /home/ngigesig/public_html/phpbb/di/container_builder.php(212): Symfony\Component\DependencyInjection\ContainerBuilder->compile()
#8 /home/ngigesig/public_html/common.php(115): phpbb\di\container_builder->get_container()
#9 /home/ngigesig/public_html/adm/index.php(23): require('/home/ngigesig/...')
#10 {main}
