<span class="qte-attr qte_31_32-qte">3.1.x & 3.2.x</span>
Posts: 6466 Joined: 13 Jan 2014, 21:45
Post
by dmzx » 13 Dec 2014, 14:33
Extension Name: Member time counter
phpBB 3.1 extension that will display member time counter in profile.
dmzx/Member-time-counter
Code update, validation version
Download the latest release.
Unzip the downloaded release, and change the name of the folder to `membertimecounter `.
In the `ext ` directory of your phpBB board, create a new directory named `dmzx ` (if it does not already exist).
Copy the `membertimecounter ` folder to `/ext/dmzx/ ` if done correctly, you'll have the main extension class at
(your forum root)/ext/dmzx/membertimecounter/composer.json
Look for `Member time counter ` under the Disabled Extensions list, and click its `Enable ` link.
Sycron
Posts: 4 Joined: 22 Nov 2014, 21:21
Post
by Sycron » 13 Dec 2014, 14:37
LE: I found on Martin forum for 3.0.12
Posts: 5105 Joined: 06 Apr 2014, 16:12
Post
by martin » 13 Dec 2014, 14:51
Sycron wrote: LE: I found on Martin forum for 3.0.12
Your find most of the edits come from mine
Allen42
Posts: 5 Joined: 12 Dec 2014, 02:33
Post
by Allen42 » 13 Dec 2014, 16:37
Like Rich McGirr (RMcGirr83) has that on his site, so it's working!
testing
Posts: 6 Joined: 11 Dec 2014, 18:27
Post
by testing » 13 Dec 2014, 17:06
Nice, you can make an extension that shows in member profile "last activity was since 12 minutes at forum XXX" maybe?
Posts: 356 Joined: 02 Nov 2014, 21:25
Post
by Jaantje » 16 Dec 2014, 07:40
Where should I apply the changes?
In Language en or in Language nl or in ext/dmzx/membertimecounter/language/en/membertimecounter.php
Or should I create a new language folder !!
Midway
Posts: 115 Joined: 08 Dec 2014, 10:27
Post
by Midway » 16 Dec 2014, 11:52
You can't change in
ext/dmzx/membertimecounter/styles/prosilver/template/event/overall_footer_after.html
you have this
<!-- INCLUDEJS jquery.jcountdown.min.js -->
// <![CDATA[
$(document).ready(function(){
$("#member").countdown({
date: '{MEMBER_FOR}',
leadingZero: false,
yearsAndMonths: true,
htmlTemplate: "<span class='cd-online'></span> <strong>%y</strong> <span class=\"cd-online\">Years</span> <strong>%m</strong> <span class=\"cd-online\">Months</span> <strong>%d</strong> <span class=\"cd-online\">{L_DAYS}</span> <strong>%h</strong> <span class=\"cd-online\">{L_HOURS}</span> <strong>%i</strong> <span class=\"cd-online\">{L_MINUTES} and</span> <strong>%s</strong> <span class=\"cd-online\">{L_SECONDS}</span>",
direction: "up"
</script>
you can't replace Years and Months of the html by your language key for example Years by {L_YEARS} and add in /language/nl/common.php
Post
by Jaantje » 16 Dec 2014, 18:52
Cerrone , je vous remercie pour la solution. Vous langue néerlandaise est meilleure que la mienne
Cerrone , thank You for the solution.
awr
Posts: 55 Joined: 13 Mar 2015, 08:50
Post
by awr » 30 Mar 2015, 08:21
Turkish language pack
tr.rar
This link updated.
awr on 30 Mar 2015, 11:51, edited 1 time in total.
awr
Post
by awr » 30 Mar 2015, 09:36
member time counter does not appear
Post
by dmzx » 30 Mar 2015, 11:03
awr wrote: membertime.jpg
Check if there is a conflict in .js on your site
awr
Post
by awr » 30 Mar 2015, 12:02
dmzx wrote: Check if there is a conflict in .js on your site
phpBB • Member time counter
Problem in this link.
Post
by dmzx » 30 Mar 2015, 21:24
What is the value user_regdate of the user in your database?
Post
by Jaantje » 30 Mar 2015, 22:29
awr I deleted the background of your avatar , you might find it more beautiful.
