3.3.x Extensions Database 3.2 / 3.3Info to Zip
Info to Zip
Extension Name: Info to Zip
Author: dmzx & martin
Text to Zip file that will generate a URL link.
Explanation:
Permissions are set default for Admins to do all.
Permission REGISTERED is set to download zip files by default. (so UCP and Tab in posts are off)
You need to set permission to the groups you would like to use the ext. (uploaders for example..)
Bots and groups that are not set are excluded.
When text field is filled and "make zip file" is clicked the zip link will show and the file is place in man root info_to_zip directory. (all links on own server)
zip will start with user_id than random number.
Quick insert of the generated encoded url can be used to insert into post. (bbcode to show the download link)
By clicking the url is decoded, than can click again to download.
Admins can see UCP tab (default) to see own zip posted or all zip posted in the forum and by who.
Others will be posted..
Info to Zip v1.0.0
  2. Unzip the downloaded release, and change the name of the folder to `infotozip`.
  4. Copy the `infotozip` folder to `/ext/dmzx/` if done correctly, you'll have the main extension class at
    (your forum root)/ext/dmzx/infotozip/composer.json
  6. Look for `Info to Zip` under the Disabled Extensions list, and click its `Enable` link.
nou nou
Re: Info to Zip
Post by nou nou »
Download link is broken?
Re: Info to Zip
nou nou wrote: 29 Mar 2025, 23:44 Download link is broken?
Changed!
