3.3.x Extensions Database 3.2 / 3.3Push Message
Push Message
Extension Name: Push Message
Author: dmzx & martin
Push Message, message short messages to notify members. Email option also available, check notifications settings to set it.
If you phpBB Browser Push Notifications is installed browser will notify you.
- Add code to show sent/received messages on push message page, ACP included.
- Code update for mChat @ integration.
- Code update generate_text_for_storage for message.
- Changed username input.
- Deleted code for Order by.
Push Message v1.0.4
  2. Unzip the downloaded release, and change the name of the folder to `pushmessage`.
  4. Copy the `pushmessage` folder to `/ext/dmzx/` if done correctly, you'll have the main extension class at
    (your forum root)/ext/dmzx/pushmessage/composer.json
  6. Look for `Push Message` under the Disabled Extensions list, and click its `Enable` link.
Re: Push Message
Re: Push Message
Is it responsive for Opera GX ?
Re: Push Message
No it is os based.
Windows it shows bottom right corner.
Linux top of screen in the center.
It is not browser styled.
Re: Push Message
martin wrote: 12 Feb 2025, 00:49 No it is os based.
Thanks for the answer Martin ! :buigen:
appriciated
SpIdErPiGgY
Re: Push Message
Post by SpIdErPiGgY »
INSERT INTO phpbb_pushmessage_log (pushmessage_send, pushmessage_recv, pushmessage_comment, pushmessage_type, pushmessage_date) VALUES (2, 349, 'Dit is een test 😒', '1', 1740221413)
Re: Push Message
SpIdErPiGgY wrote: 22 Feb 2025, 11:48
Thanks for the report, will be solved in next release :thumbup:
Re: Push Message
SpIdErPiGgY
Re: Push Message
Thank you, emoji works now 😁
Re: Push Message
SpIdErPiGgY wrote: 22 Feb 2025, 22:19 Thank you, emoji works now 😁
Re: Push Message
fastgil.com
Re: Push Message
Post by fastgil.com »
fr.rar
FR version
Check if I'm receiving a message in the mchat
miri4ever
Re: Push Message
Post by miri4ever »
If MChat Support is on, I get this error message if I submit, and it first throws out this error, and after refreshing, the message is displayed in MChat, but the user just got an empty message.
