Extensions notes [Add On]
Post Reply
Extension Name: Extensions notes [Add On]
Author: dmzx & martin
Extensions notes [Add On] needs viewtopic.php?p=32569#p32569, add notes to your extension.
- Add code to see note available on settings page.
Extension notes v1.0.1
  2. Unzip the downloaded release, and change the name of the folder to `extensionnotes`.
  4. Copy the `extensionnotes` folder to `/ext/dmzx/` if done correctly, you'll have the main extension class at
    (your forum root)/ext/dmzx/extensionnotes/composer.json
  6. Look for `Extensions notes` under the Disabled Extensions list, and click its `Enable` link.
Re: Extensions notes [Add On]
iorG19
Post by iorG19 »
// Romanian translation for this extension; download and upload to the forum's /ext directory.
// Traducere în limba română a acestei extensii: descarcă și urcă în directorul /ext al forumului.
dmzx-extensionnotes-1.0.1_ro.zip
Post Reply
