3.3.x Extensions Database 3.2 / 3.3Extension Check [Add On]
Extension Name: Extension Check [Add On]
Extension Check [Add On] needs Admin Config Page will show extension installed extensions.
Enable and disable function or if the extension needs to be updated.
Note: Boards with alot of extension installed will take some time to load
Extension Check v1.0.0
  2. Unzip the downloaded release, and change the name of the folder to `extensioncheck`.
  4. Copy the `extensioncheck` folder to `/ext/dmzx/` if done correctly, you'll have the main extension class at
    (your forum root)/ext/dmzx/extensioncheck/composer.json
  6. Look for `Extension Check` under the Disabled Extensions list, and click its `Enable` link.
iorG19
    unknown Chrome
Re: Extension Check [Add On]
Post by iorG19 »
// Romanian translation for this extension; download and upload to the forum's /ext directory.
// Traducere în limba română a acestei extensii: descarcă și urcă în directorul /ext al forumului.
dmzx-extensioncheck-1.0.0_ro.zip
