3.3.x Extensions Database 3.2 / 3.3Add Meta
Add Meta
Extension Name:
Adds meta information to your board, needed for some new extension releases.
Just install no need to setup anything.
Add Meta v1.0.0
  2. Unzip the downloaded release, and change the name of the folder to `addmeta`.
  4. Copy the `addmeta` folder to `/ext/dmzx/` if done correctly, you'll have the main extension class at
    (your forum root)/ext/dmzx/addmeta/composer.json
  6. Look for `Add Meta` under the Disabled Extensions list, and click its `Enable` link.
