Extension official releasesphpbb [3.3.x] Extensions Database Releases • gTranslate
Extension name: gTranslate
Author: HiFiKabin
Extension description: Extension Name: gTranslate
Author: HiFiKabin
Extension Description: Adds gTranslate to your board. This is a replacement for my Google Translator whose code is now at its end of life
Limitations: This extension packages the gTranslate code for easy use on phpBB so its operation is limited to how they have written that code.
The gTranslate code translates THE WHOLE PAGE, including Topics, Categories, Usernames etc.
Some spaces in the template are removed but this does not effect readability.
If you are using the board in a translated language not all of the Moderation Tools will function.
It sets the default language to that of your browser.
Omit Translation: You can omit text from being translated by one of the following methods:-
1) HTML (Template files)
Wrap the text you want to be omitted within
Code:
2) BBCode (Posts and PM's)
BBCode Usage
Code:
[notranslate]{TEXT}[/notranslate]HTML Replacement
Code:
{TEXT}.Help Line
Code:
NoTranslateExtension Version: 3.3.1
Language: all
Supported Styles: all
Live Demo: HERE
IMPORTANT: If you are migrating from my Google translator extension, you MUST disable it as well as delete its Data BEFORE installing gTranslate
  • Download the latest release and unzip it.
  • Upload the folder hifikabin to root/ext/ and enable it in the ACP
Support:
Here or My Extensions Board
Extension version: 3.3.1
Tested on phpBB version: 3.3.10
Download file: gtranslate_3_3_1.zip
File size: 7.77 KiB
Source: [url]https://www.phpbb.com/community/viewtopic.php?p=15975226#p15975226
