Extension official releasesphpbb [3.2.x] Extensions Database Releases • Header Link
Extension name: Header Link
Author: HiFiKabin
Extension description: Adds links at the top of the forum. You can add FA icons, colour the button, add shadow, control who has access to the link and more. Unused links do not appear as blank spaces as they are all aligned to the left (right in rtl languages) You can enter the HTML color you would like eg #0C93D7 or use the colour picker supplied. On Hover colour is also configurable.
An 'Advanced Search' icon is placed in the Breadcrumbs if that option is selected.
Leaving the URL field empty on form submit deletes that button.
Compatible with my Sticky Bar Extension
The FA ICON codes can be found here and need to be entered as fa-file-pdf-o
On smaller screens the button size is reduced, corners less rounded, the FA icon removed and only the beginning of the buttons name is shows. The "On Hover" text is still shown in full. The 'Link' button will not function on small devices that have JavaScript disabled and is hidden from view.
Based on and adapted from the link bar on phpBB.com
Thanks to Lumpy Burgertushie for assembling the Style files and especially to my BETA testers who have helped to make this extension what it has become.
Extension Version: 3.2.2
Language: Supported Styles:
  • prosilver
  • Most prosilver based styles
Live Demo: HERE
  • Download the latest release and unzip it.
  • Upload the folder hifikabin to root/ext/ and enable it in the ACP
Support:
The contact us link at the bottom of this Board or This Topic
Extension version: 3.2.2
Download file: headerlink_3_2_2.zip
File size: 74.98 KiB
Source: [url]https://www.phpbb.com/community/viewtopic.php?p=15974845#p15974845
