3.3.x Extensions Database 3.2 / 3.3User check
User check
Extension Name: User check
User check registration, checks if member already has an account registered so no double accounts will be allowed.
Can check if member use proxy to register doible account.
- Language update.
User check v1.0.1
  2. Unzip the downloaded release, and change the name of the folder to `usercheck`.
  4. Copy the `usercheck` folder to `/ext/dmzx/` if done correctly, you'll have the main extension class at
    (your forum root)/ext/dmzx/usercheck/composer.json
  6. Look for `User check` under the Disabled Extensions list, and click its `Enable` link.
Banned
Banned
Re: User check
Re: User check
Thanks, works with DAP (Double Account Preventer) also :)
The Good
Re: User check
Post by The Good »
I have requested this kind of ext my user phpbb is BF79 :smile: and also thx Tread..
I didnt tried yet.. my question if this ext can detect multi accounts from members already register before installation of ext
Banned
Banned
Re: User check
With the DAP extension in the ACP you have a double user log, which you can delete at will. On the other hand this extension does not prevent the recording of multi-accounts (I do not believe it)
The User Check extension can block accounts on registration.
The Good
Re: User check
Post by The Good »
ssl wrote: 04 Feb 2023, 18:18 With the DAP extension in the ACP you have a double user log, which you can delete at will. On the other hand this extension does not prevent the recording of multi-accounts (I do not believe it)
more info about DAP extension ? where ?
Banned
Banned
Re: User check
You will find the link in your open post on phpbb.com
I quote you:
this ext is for new register..doesnt allow new members register twice..
its not my idea of request.. my idea its just inform admin about double accout with same ip login
Re: User check
Dap ext is out dated and needs to have work done to it to work the version linked to on .com is junk but i do have an updated working version on 3.3
Banned
Banned
Re: User check
Extract from composer.json file of DAP version 1.0.3
"description": "Double Account Preventer for phpBB 3.1/3.2/3.3",
This ext work fine with phpBB 3.3.10-RC1
Re: User check
DAP also don't check if user use proxy for second account registration.
Banned
Banned
Re: User check
Already said here: User check
Re: User check
Will post version 1.0.1 soon btw
Re: User check
Not ready for release yet.
Re: User check
Ghost
Re: User check
Post by Ghost »
With the new Firefox version 112.0.2 (64-bit), this Ext no longer works.
He no longer shows me that I already have an account.
Mit dem neuem Firefox Version 112.0.2 (64-Bit) geht diese Ext nicht mehr.
Er zeigt mir nicht mehr an das ich schon ein Konto habe.
