3.2.x Extensions Database 3.2 / 3.3Stat Block For 3.3.x
HarveyWNvm LLC.
Post by HarveyWNvm LLC. »
Extension Name: Stat Block
Author: HarveyWNvm LLC.
No Demo...
stat_block_3_3_5.zip
  2. Unzip the downloaded release, and change the name of the folder to `hrvy `.
  3. In the `ext` directory of your phpBB board, create a new directory named `hrvy` (if it does not already exist).
  4. Copy the ` file` folder to `/ext/hrvy/` if done correctly,
nFL-Cs.InFo Clock to Banner
Re: Stat Block For 3.3.x
umi
Post by umi »
What`s that?
No info about ext...
Adds a forabg around the stats section.
Note it uses hard coded lang also css in html files which is a no no if submitted to phpbb.
