3.3.x Extensions Database 3.2 / 3.3Last post subject truncated
Extension Name: Last post subject truncated
Last post subject truncated v1.0.0
  2. Unzip the downloaded release, and change the name of the folder to `lastpostsubjecttruncated`.
  4. Copy the `lastpostsubjecttruncated` folder to `/ext/dmzx/` if done correctly, you'll have the main extension class at
    (your forum root)/ext/dmzx/lastpostsubjecttruncated/composer.json
  6. Look for `Last post subject truncated` under the Disabled Extensions list, and click its `Enable` link.
Re: Last post subject truncated
Truncet text means shorten text? :roll:
ivailo95 wrote: 20 Jul 2021, 17:21 Truncet text means shorten text? :roll:
Yes if long topic text is used you can shorten it.
