Author: Sajaki
Extension description: Extension for phpBB 3.2 / 3.3 to let visitors quickly switch board styles.
Based on Prime Quick Style for phpBB 3.0, by Ken F. Innes IV (primehalo)
Features:
- Adds a drop-down selector to the header, which detects a selection change and triggers a board style change through the UCP.
- Automatically redirects back to the original page being viewed after style has changed.
- Works for guests too, but uses a special cookie instead.
- ACP module to set guest access and whether to use the default template location: EVENT overall_header_navigation_prepend
- Download and unzip the current release.
- Copy the paybas/quickstyle folder to /ext/paybas/quickstyle.
- Navigate in the ACP to Customise -> Manage extensions.
- Look for "Quick Style" under the Disabled Extensions list, and click the "Enable" link.
- Set up and configure the Quick Style extension by navigating in the ACP to Extensions -> Quick Style.
Version 1.4.3 is currently in the validation queue.
Extension version: 1.4.3
Download file: quickstyle-1.4.3.zip
File size: 45.31 KiB
Source: [url]https://www.phpbb.com/community/viewtopic.php?t=2595041&p=15725411#p15725411
