3.3.x Extensions Database 3.2 / 3.3Topic Image
Topic Image
Extension Name: Topic Image
Author: dmzx & martin
Special thanks to: clight77 for making this development possible.
Topic image on index extension.
dmzx/Topic-Image
- Added WebP case.
- Added title to images option and colour option.
- Added width selection in APC.
- Added limit for images in topics.
- Added Cron for deleting and grabbing images.
- Code updates.
Topic Image v1.0.3
  2. Unzip the downloaded release, and change the name of the folder to `topicimage`.
  4. Copy the `topicimage` folder to `/ext/dmzx/` if done correctly, you'll have the main extension class at
    (your forum root)/ext/dmzx/topicimage/composer.json
  6. Look for `Topic Image` under the Disabled Extensions list, and click its `Enable` link.
Re: Topic Image
First post taken....
Re: Topic Image
Thanks, I like it :)
Suits my site :)
Re: Topic Image
Just a suggestion.
I think ext could have a auto prune function in ACP for the oldest as it seems after 1000 - 1500 images site tends to slow down.
Possible to do ?
Cheers :
Hamidouki-dz
Re: Topic Image
Post by Hamidouki-dz »
does the extension function on phpbb version 3.2.7
Re: Topic Image
clight77 wrote: 27 Feb 2021, 17:17Just a suggestion.
Sniper_E wrote: 27 Feb 2021, 17:38Just a suggestion.
You should update your phpbb version 3.2.7 to 3.3.3
Re: Topic Image
Hamidouki-dz wrote: 03 Mar 2021, 09:13 Hello
No only: PHPBB_VERSION, '3.3.0', '>='
Hamidouki-dz
Re: Topic Image
I have a lot of html code on my forum, and it is difficult to update it otherwise I will have a lot of problems fixing the errors.
Re: Topic Image
Then you just learnt a lesson dont edit core files.
Re: Topic Image
Dm has an extension that will allow you to make those core edits, then you can do phpbb updates and still have your ext core edits.
faroud
Re: Topic Image
Post by faroud »
How does that work?
I uploaded it and turned it on
but don't see anything?
Re: Topic Image
faroud wrote: 03 Mar 2021, 18:57 how does that work?
click on a forum or 2 that contains images then they should show, select forums in ACP Image Topic 1st.
Re: Topic Image
I will post a how to use soon for this.
Re: Topic Image
Select the forums you want to get images from and then click on grab now button.
You can also set group permissions to grab images this will update images also as members surf your board.
Note it only works on img tags not attachments.
umi
Re: Topic Image
Post by umi »
Spanish Language
es.zip
:beers: :beers: :beers:
