Extension official releasesphpbb [3.2.x] Extensions Database Releases • Pastebin
Extension name: Pastebin
Author: Crizzo
Extension description: Description
This extension adds a pastebin into your phpBB board including syntax highlighting.
Github Repository: https://github.com/phpbb-de/phpbb-ext-pastebin
Installation
Copy the content of this repository via git clone:
Code:
git clone https://github.com/phpbb-de/phpbb-ext-pastebin ext/phpbbde/pastebinor create the following directory structure in your phpBB-root directory:Code:
ext/phpbbde/pastebinand copy the repository content to it.
Go to "ACP" > "Customise" > "Extensions" and enable the "Pastebin" extension.
Added permissions
The extension adds on the first install group permissions to "user standard" role and "Standard Moderator" and "Full Moderator" roles. You will find them in the user or moderator roles tab "Pastebin".
New user permissions:
  • Can delete own pastebin entries
  • Can edit own pastebin entries (Storage duration, Syntax highlighting)
  • Can post pastebin entries
  • Can post non-pruned pastebin entries
  • Can post pastebin entries without visual confirmation
  • Can view pastebin entries
New moderator permissions:
  • Can delete pastebin entries
  • Can edit pastebin entries (Storage duration, Syntax highlighting)
  • Can deactivate pruning of selected pastebin entries
Development and bug reports
If you find a bug, please report it on https://github.com/phpbb-de/phpbb-ext-pastebin/issues
Extension version: 2.0.4
Tested on phpBB version: 3.2.10
Download file: phpbbde_pastebin_2_0_4.zip
File size: 1.36 MiB
Source: [url]https://www.phpbb.com/community/viewtopic.php?t=2567966&p=15592136#p15592136
