3.2 & 3.3 Extensions Database 3.2 / 3.3Better Ranks
riofriz
Better Ranks
Post by riofriz »
Extension Name: Better Ranks
Author: riofriz
Special thanks to: dmzx for the support and Posey for the original idea
Allows users to display every group that has a rank connected to it (as long as it has a banner image) on post view, profile view and pm view. Users will also be able to manage which banners will be shown from UCP -> Profile -> Banners.
Ranks that are directly assigned to users without going through Groups first, won't be showing in the UCP and will take priority over groups (will basically show on the very top).
Extension Download: Download-linkBetter Ranks v2.0.1 Installation:
  2. Unzip the downloaded release, and change the name of the folder to `betterranks`.
  3. In the `ext` directory of your phpBB board, create a new directory named `vcc` (if it does not already exist).
  4. Copy the `betterranks` folder to `/ext/vcc/` if done correctly, you'll have the main extension class at
    (your forum root)/ext/vcc/betterranks/composer.json
  6. Look for `Better Ranks` under the Disabled Extensions list, and click its `Enable` link.
riofriz
Re: Better Ranks
Post by riofriz »
Fixed bug on pm view, if users removed every single banner it'd throw an exception.
No need to disable/delete data, just get the latest code on your server.
Changelog:
https://github.com/riofriz/vcc_betterranks/commit/b0ad0987972567985a2398b835da2f8c5f6a54ff#diff-5b16f81e26748b1551589589de97e98a
SalyaDarken
Re: Better Ranks
Post by SalyaDarken »
Wow I been looking for something like this. Thanks. ^^
Keep up the good work!
riofriz
Re: Better Ranks
Post by riofriz »
SalyaDarken wrote: 6 years ago wow I been looking for something like this. Thanks. ^^
Thanks! Glad someone else found it useful :tumbsyes:
miri4ever
Re: Better Ranks
Post by miri4ever »
Got this error if watching banners:
phpbb_user_group' doesn't exist [1146]
SQL
SELECT phpbb_user_group.order, phpbb_user_group.show_banner, phpbb_user_group.group_id, phpbb_groups.group_name, phpbb_groups.group_colour, phpbb_users.user_rank, phpbb_groups.group_rank, phpbb_ranks.rank_image, phpbb_user_group.user_id FROM phpbb_user_group LEFT JOIN phpbb_users ON phpbb_users.user_id = phpbb_user_group.user_id LEFT JOIN phpbb_groups ON phpbb_user_group.group_id = phpbb_groups.group_id LEFT JOIN phpbb_ranks ON phpbb_ranks.rank_id = phpbb_groups.group_rank WHERE phpbb_groups.group_rank != 0 AND phpbb_user_group.user_id = 4 ORDER BY phpbb_user_group.order ASC
Not everyone using phpbb_ as table prefix only.
riofriz
Re: Better Ranks
Post by riofriz »
miri4ever wrote: 6 years ago Got this error if watching banners:
SQL
Will sort tomorrow, thanks for reporting it :)
riofriz
Re: Better Ranks
Post by riofriz »
Extension updated to 2.0.1, fixed the issue reported by miri4ever, added translatable text and general performance improvements.
Thanks dmzx for the changes!
miri4ever
Re: Better Ranks
Post by miri4ever »
Banners now display fine but if I hit the checkbox at the banners and pressing submit button I got this:
AJAX-FEHLER
Service Unavailable
So it seems I cant select or deselect any of the banners.
riofriz
Re: Better Ranks
Post by riofriz »
miri4ever wrote: 6 years ago Banners now display fine but if I hit the checkbox at the banners and pressing submit button I got this:
AJAX-FEHLER
Service Unavailable
Uhm, this doesn't happen to me, did you clear the cache after updating the module?
Try
rm -rv cache/production/*
from the phpbb root folder
miri4ever
Re: Better Ranks
Post by miri4ever »
I try but it wont helped me. Can't turn off any of those I dont want to display. I dont know if this is a result from phpbb 3.3.0 still having a lot of problems with AJAX Buttons or if you runing an older version. Just can tell you what I saw on mine in hope it was a real bug maybe to others aswell.
spaceworld
Re: Better Ranks
Post by spaceworld »
doesn't work to me ... 3.3.2 can't see ! :eyes2:
SalyaDarken
Re: Better Ranks
Update plz
Re: Better Ranks
Just tested and still works for me.
What is not working for you?
spaceworld
Re: Better Ranks
dmzx wrote: 5 years ago Just tested and still works for me.
Hello Thx for your reply !
It's ok now ... perfect ! I don't know what's the problem before ... Maybe the cache ! ...
Best
Kimera_V2
Re: Better Ranks
Post by Kimera_V2 »
Error after backup restore:
SQL ERROR [ mysqli ]
You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'order) VALUES (5, 2, 1, 0, 1, 1),(4, 2, 1, 0, 1, 1),(4, 63, 0, 0, 1, 1),(2, 71, ' at line 1 [1064]
SQL
INSERT INTO phpbb_user_group (group_id, user_id, group_leader, user_pending, show_banner, order) VALUES (5, 2, 1, 0, 1, 1),(4, 2, 1, 0, 1, 1),(4, 63, 0, 0, 1, 1),(2, 71, 0, 0, 1, 1),(2, 63, 0, 0, 1, 1),(2, 2, 0, 0, 1, 1),(2, 68, 0, 0, 1, 1),(2, 69, 0, 0, 1, 1),(2, 64, 0, 0, 1, 1),(10, 2, 0, 0, 1, 1),(12, 71, 0, 0, 1, 1),(12, 2, 0, 0, 1, 1),(8, 71, 1, 0, 1, 1),(1, 1, 0, 0, 1, 1),(11, 2, 1, 0, 1, 1),(6, 3, 0, 0, 1, 1),(6, 4, 0, 0, 1, 1),(6, 5, 0, 0, 1, 1),(6, 6, 0, 0, 1, 1),(6, 7, 0, 0, 1, 1),(6, 8, 0, 0, 1, 1),(6, 9, 0, 0, 1, 1),(6, 10, 0, 0, 1, 1),(6, 11, 0, 0, 1, 1),(6, 12, 0, 0, 1, 1),(6, 13, 0, 0, 1, 1),(6, 14, 0, 0, 1, 1),(6, 15, 0, 0, 1, 1),(6, 16, 0, 0, 1, 1),(6, 17, 0, 0, 1, 1),(6, 18, 0, 0, 1, 1),(6, 19, 0, 0, 1, 1),(6, 20, 0, 0, 1, 1),(6, 21, 0, 0, 1, 1),(6, 22, 0, 0, 1, 1),(6, 23, 0, 0, 1, 1),(6, 24, 0, 0, 1, 1),(6, 25, 0, 0, 1, 1),(6, 26, 0, 0, 1, 1),(6, 27, 0, 0, 1, 1),(6, 28, 0, 0, 1, 1),(6, 29, 0, 0, 1, 1),(6, 30, 0, 0, 1, 1),(6, 31, 0, 0, 1, 1),(6, 32, 0, 0, 1, 1),(6, 33, 0, 0, 1, 1),(6, 34, 0, 0, 1, 1),(6, 35, 0, 0, 1, 1),(6, 36, 0, 0, 1, 1),(6, 37, 0, 0, 1, 1),(6, 38, 0, 0, 1, 1),(6, 39, 0, 0, 1, 1),(6, 40, 0, 0, 1, 1),(6, 41, 0, 0, 1, 1),(6, 42, 0, 0, 1, 1),(6, 43, 0, 0, 1, 1),(6, 44, 0, 0, 1, 1),(6, 45, 0, 0, 1, 1),(6, 46, 0, 0, 1, 1),(6, 47, 0, 0, 1, 1)
BACKTRACE
FILE: (not given by php)
LINE: (not given by php)
CALL: msg_handler()
LINE: 994
CALL: trigger_error()
LINE: 196
LINE: 329
FILE: [ROOT]/includes/acp/acp_database.php
LINE: 257
CALL: phpbb\db\driver\factory->sql_query()
LINE: 676
CALL: acp_database->main()
FILE: [ROOT]/adm/index.php
LINE: 82
CALL: p_master->load_active()
