Extension name: Sortables Captcha
Author: Derky
Extension description: Sortables Captcha Extension for phpBB 3.2. This captcha plugin allows you to add questions and provide answers in two seperate columns. An user will see all the answers in one column and has to drag some answers to the other column to successfully complete the captcha.
Live Demo
So how is this exactly working? Try it out now!
Translations
Already available in 27 different languages! Most translations are included in the download package but for the latest added translations see:
The list of available translations and how you can submit yours.
Installation & Updates
How to install Sortables Captcha
How to update Sortables Captcha
phpBB 3.3 error The reserved indicator '@' cannot start a plain scalar
For phpBB 3.3 please apply this fix manually: https://github.com/Derky/Sortables-CAPT ... l/19/files
A new version will be submitted to phpBB.com soon.
This extension works on phpBB 3.1.0 and higher. (Also 3.2.0 and up) The older version for phpBB 3.0.14 can be found here.
Extension version: 2.0.2
Download file: sortables_captcha_2.0.2.zip
File size: 140.15 KiB
Source: [url]https://www.phpbb.com/community/viewtopic.php?t=2555616&p=15521836#p15521836
Extension official releases ⇒ phpbb [3.3.x] Extensions Database Releases • Sortables Captcha
- Dmzx-web.net
