3.3.x Extensions Database 3.2 / 3.3Copyright Extended
Copyright Extended
Extension Name: Copyright Extended
Copyright Extended
- Code cleanup.
- Code update version ACP.
- Style adm update.
  2. Unzip the downloaded release, and change the name of the folder to `copyrightextended`.
  4. Copy the `copyrightextended` folder to `/ext/dmzx/` if done correctly, you'll have the main extension class at
    (your forum root)/ext/dmzx/copyrightextended/composer.json
  6. Look for `Copyright Extended` under the Disabled Extensions list, and click its `Enable` link.
Re: Copyright Extended
admin1
    Android Firefox
Post by admin1 »
:mml:
Very very good extension. Very good !
Barrybrennan
Post by Barrybrennan »
Thank you 🙂
Copyright Extended_1.0.2-Slovenian.zip
