Author: Blitze
Extension description: phpBB SiteMaker allows you to transform your phpBB3 board into a full-blown site
Features:
- Customize your site using blocks of content
- Drag and drop interface for adding/removing blocks
- Customizable block display - background color, title, etc
- Set any front-facing controller as your site's landing page
- Create layouts for each page or set a default layout for your entire site
- Icon picker for choosing blocks/menu icons using font awesome
- Limit access to specific blocks based on group memberships
- Create Menus with nested lists
- Create blocks with your own content using html/bbcode
- And much more ...much more ...
phpBB 3.2.1 or newer
Documentation Repo:
https://github.com/blitze/phpBB-ext-sitemaker
Demo:
http://www.phpbb-sitemaker.website/demo-3.2.x/
username: demo
password: password
- Download and unzip the current release.
- Upload the extracted package into the ext directory of your phpBB board.
- Navigate in the ACP to Customise -> Manage extensions.
- Look for SiteMaker under the Disabled Extensions list and enable it.
- Disable (do not Purge) phpBB Primetime
- Install phpBB Sitemaker as described above
- Purge phpBB Primetime
Download file: blitze_sitemaker_3.2.1.zip
File size: 2.63 MiB
Source: [url]https://www.phpbb.com/community/viewtopic.php?t=2551616&p=15496096#p15496096
