3.2 & 3.3 Extensions DatabaseReply to see content
Extension Name: Reply to see content
Reply to see content in topic. Member has to make a reply to see the content in the topic.
Forum can be selected in ACP under "Manage forums" .
- Added post visibility in search.
- Added option to hide url until post reply.
- Changed code when no posts are made, no message.
- Added permission to see all content for groups.
- Changed code for review first post.
- Changed search code for first post hide when using permission.
- Fix code for viewtopic.
- Added permission to see first post content.
Above can set the forum you like to hide the content until a reply is made.
Above test topic made by admin.
Above when member did not make a reply yet.
Above member want to make a reply but cannot see the review and also quote buttons are disabled.
If reply needs approve the topic will not show until approve is done.
Above member did make reply and see all posts in topic.
Above other member wants to search the words but cannot see the post.
Above other member cannot see when he search on members posts until here replies also in that topic.
Reply to see content v1.0.4
  2. Unzip the downloaded release, and change the name of the folder to `replytoseecontent`.
  4. Copy the `replytoseecontent` folder to `/ext/dmzx/` if done correctly, you'll have the main extension class at
    (your forum root)/ext/dmzx/replytoseecontent/composer.json
  6. Look for `Reply to see content` under the Disabled Extensions list, and click its `Enable` link.
This topic has 35 replies
