Author: HiFiKabin
Extension description: Extension Description: Adds the phases of the moon to your forum header. As the previous version did not work correctly on secure hosting I have loaded the image via a ssl proxy server to ensure that this extension does not give any more 'mixed content' warnings. Obviously it will also work on non ssl sites.
There is a UCP switch to rotate the moon image by 180 degrees for those in the Southern Hemisphere
Note: The dynamic image of the moon is © http://www.calendrier-lunaire.net and remotely loaded from their website with permission.
Requirements: phpBB 3.1.4 or later
Language:
- EN
- Additional Lang Pack ar, de, de-x-sie, es, es_x_tu, fr, nl, ru
- prosilver
- Download the latest release and unzip it.
- Upload the the folder hifikabin to root/ext/ and enable it in the ACP
The contact us link at the bottom of this Forum or phpBB Forum
Extension version: 1.0.8
Download file: moonphase_1_0_8.zip
File size: 13 KiB
Source: [url]https://www.phpbb.com/community/viewtopic.php?t=2544241&p=15450611#p15450611
