3.3.x Extensions Database 3.2 / 3.3Newsletter
Newsletter
Extension Name: Newsletter
This adds newsletter option in ACP.
Added html support for emails. (requires HTML email extension)
- Added template save in ACP.
- Code update for email.
- Changed code messenger.
- Code update
- Add acp_contoller.
- Fixed Search for user.
  2. Unzip the downloaded release, and change the name of the folder to `newsletter`.
  4. Copy the `newsletter` folder to `/ext/dmzx/` if done correctly, you'll have the main extension class at
    (your forum root)/ext/dmzx/newsletter/composer.json
  6. Look for `Newsletter` under the Disabled Extensions list, and click its `Enable` link.
Midway
Re: Newsletter
Post by Midway »
When I click on search for a member to select a username nothing happens, the member's name does not appear and the popup window stays open.
Anders
Re: Newsletter
Post by Anders »
I can confirm that have same issue
Re: Newsletter
Midway wrote: 27 Feb 2020, 14:12 when I click on search for a member to select a username nothing happens, the member's name does not appear and the popup window stays open.
Yes I see will be fixed in next update.
Midway
Re: Newsletter
Post by Midway »
Now it's ok with 1.0.1 version thanks dmzx :thumbup:
Re: Newsletter
Midway wrote: 27 Feb 2020, 15:10 Now it's ok with 1.0.1 version thanks dmzx :thumbup:
:wink:
Re: Newsletter
Almohsin
Re: Newsletter
Post by Almohsin »
Thank you, great job.👌
medic
Re: Newsletter
Post by medic »
Hi tx for this extension
I have nearly 400 members I sent a newsletter I got error timeout request
Not sure if all members got the email
My question is there a way to fix it
Phpbb 3.3.4
Php 7.4.20
Ovh
And got banned from the host consider as spam they allow just 100 mail /hour
Thank you
medic
Re: Newsletter
Post by medic »
Any help plz
Re: Newsletter
medic wrote: 18 Jun 2021, 14:13 Hi tx for this extension
Phpbb 3.3.4
Php 7.4.20
Ovh
Thank you
This is probably host issue, if they don't set the value higher or you cannot set it you will be blocked by them.
If you cannot set other server option by the host, I would recommend to switch host...
medic
Re: Newsletter
Post by medic »
Ok thank you they told me to switch queu in phpbb config 60 to 600 and fix paquest to 15 so in this it will allow sent 90 mail/hour
I didn't hope don't get banned again
medic
Re: Newsletter
Post by medic »
The second newsletter didn't been sent to the most of members server error 500 timeout
I fixed all sets as they say paquest to 15 and queue 600
they add some cron in cpanel not sure if it enoupgh
i used mass mail phpbb it work fine without html of course can u add the buton send later or make this extension work with queu plz
thank you for the extension the only one working tosend html email
medic
Re: Newsletter
Post by medic »
Up plz
Re: Newsletter
medic wrote: 24 Jun 2021, 17:24 The second newsletter didn't been sent to the most of members server error 500 timeout
Its on my list to do, so will check it
