Author: AbaddonOrmuz
Extension description: Add dynamically generated meta tags and microdata (Open Graph, Twitter Cards and JSON-LD) of your forums and topics to improve SEO of your board and show correct information when you share it though social networks, including (but not limited to) Facebook, Twitter and Vkontakte.
Features:
- Dynamically generated Open Graph, Twitter Cards meta tags and JSON-LD microdata from your board data and current page
- Set default image for Open Graph and JSON-LD
- Set how description will be generated
- ACP settings to enable/disable Open Graph, Twitter Cards and JSON-LD
- Support for attachments, for topic image
- PHP 5.6 or greater
- phpBB 3.2 or greater
- Spanish (Formal Honorifics) [es]
- Spanish (Casual Honorifics) [es_x_tu]
If you like or found this extensions useful and want to show some appreciation, you can consider donating.
[ Donate via PayPal ]
Extension version: 1.3.0
Download file: alfredoramos_seometadata_1.3.0.zip
File size: 34.99 KiB
Source: [url]https://www.phpbb.com/community/viewtopic.php?t=2542481&p=15440481#p15440481
