3.3.x Extensions Database 3.2 / 3.3Upload Extensions 3.3.0-RC
Extension Name:
Author: LavIgor
Updated by: martin
Upload and install extensions without using FTP!
Manage extensions more quickly and effectively!
Use additional features: manage ZIP packages, view file trees, download proper ZIP packages of your extensions and more!
https://www.youtube.com/watch?v=0_O5zqXw1_o can be seen here https://www.phpbb.com/community/viewtopic.php?t=2256956
See here for download Upload Extensions 3.3.0-RC
In general you'll need to copy the contents of the uploaded zip package to `ext/boardtools/upload`.
As a result the path to the `composer.json` file should become `ext/boardtools/upload/composer.json`.
Then navigate in the ACP to `Customise -> Extension Management -> Manage extensions -> Upload Extensions` and click `Enable`.
### General information about standard updates
To update Upload Extensions in standard way navigate in the ACP to `Customise -> Extension Management -> Manage extensions -> Upload Extensions` and click `Disable`.
Then you can install the updated version of the extension.
Re: Upload Extensions 3.3.0-RC
Martin, Thanx u very much for this ext.
Everything :thumbup: with you?
Long time ago.
I am still alive :rolling:
Peralta
Post by Peralta »
Thanks martin :thumbup:
Barrybrennan
Post by Barrybrennan »
Thank you :0
Daveo
Post by Daveo »
Doesn't seem to be displaying correctly and the spinning circle seems to be stuck or taking ages
Shows the following text at top of page...
Loading
Loading erroredLoading timed out
Edit - fixed it - it was a linux files & folders permissions issue
Then your server or host is not set up correct to have that issue.
Daveo
Post by Daveo »
Issue was because I extracted zip on server instead of locally then uploading extracted zip's content to server.
Unusual as I've extracted zip's on server before and had no permission issues.
Checked permissions of folders/files whilst they are in the zip file and they are all set to 0500, instead of 0755 for folders and 0644 for files.
Managed to correct issue by manually setting the correct permissions on the folders/files.
Hensyr Wolf
    Ubuntu Firefox
Post by Hensyr Wolf »
Fantastic extension this is.
Martin thanks very much for this extension, it makes things easy
jpbc92
Post by jpbc92 »
Yes, great extension, thank you Martin. :tumbsyes:
TOT
    Linux Firefox
Post by TOT »
Thank you so much :thankyou: Goodbye FTP)
admin1
Post by admin1 »
To be honest, this extension is very good. I like it so much
:buigen:
The original author has now released a version for 3.3 :tumbsyes:
admin1
Post by admin1 »
We are seriously waiting for it badly
:wall:
This is the authors latest update for 3.3 ignore numbers.
boardtools_upload_3_2_0-RC.zip
admin1
Post by admin1 »
martin wrote: 04 Jan 2021, 00:49 This is the authors latest update for 3.3 ignore numbers.
INSTALLED.
But how is
newer than
boardtools_upload_3_3_0-RC.zip
confused :oops:
