3.3.x Extensions Database 3.2 / 3.3Show debug info in footer 3.3
Extension Name:
Author: martin
By default phpbb 3.3 no longer allows you to apply these settings like you can on 3.2.
phpbb 3.3.0 only
martin_loadtime_1_0_0.zip
  2. Unzip the downloaded release, and change the name of the folder to `loadtime `.
  3. In the `ext` directory of your phpBB board, create a new directory named `martin` (if it does not already exist).
  4. Copy the ` loadtime` folder to `/ext/martin/` if done correctly, you'll have the main extension class at
    (your forum root)/ext/martin/composer.json
  6. Look for `Load time ` under the Disabled Extensions list, and click its `Enable` link.
Re: Show debug info in footer 3.3
Files updated.
