Extension official releasesphpbb [3.2.x] Extensions Database Releases • SEO Metadata
Extension name: SEO Metadata
Author: AbaddonOrmuz
Extension description: Add dynamically generated meta tags and microdata (Open Graph, Twitter Cards and JSON-LD) of your forums and topics to improve SEO of your board and show correct information when you share if though social networks, including (but not limited to) Facebook, Twitter and Vkontakte.
Features:
  • Dynamically generated Open Graph, Twitter Cards meta tags and JSON-LD microdata from your board data and current page.
  • Set default image for Open Graph and JSON-LD.
  • Set how description will be generated
  • ACP settings to enable/disable Open Graph, Twitter Cards and JSON-LD
Requirements:
  • PHP 5.6 or greater
  • phpBB 3.2 or greater
Translations:
  • Spanish (Formal Honorifics) [es]
  • Spanish (Casual Honorifics) [es_x_tu]
Extension version: 1.2.0
Tested on phpBB version: 3.2.7
Download file: alfredoramos_seometadata_1.2.0.zip
File size: 30.59 KiB
Except where otherwise noted, the phpBB Team is not responsible nor required to provide support for this extension. By installing this extension, you acknowledge that the phpBB Support Team or phpBB Extension Customisations...
Read more
