3.2.x Extensions Database 3.2 / 3.3Forum Online
Forum Online
Extension Name: Total online Forum
Author: bb3mobi
Extension Description: Users in forum counter
Screenshots: Image
bb3mobi_total_online_forum_1_0_0.zip
  2. Unzip the downloaded release, and change the name of the folder to ` forum_online`.
  3. In the `ext` directory of your phpBB board, create a new directory named `[cbb3mobi[/c]` (if it does not already exist).
  4. Copy the `forum_online ` folder to `/ext/bb3mobi/` if done correctly, you'll have the main extension class at
    (your forum root)/ext/bb3mobi/ /composer.json
  6. Look for `See all the users for each forum ` under the Disabled Extensions list, and click its `Enable` link.
Post edited with the right author and info.
Pingui
Re: Forum Online
Post by Pingui »
Thanks ivailo95!
Be yourself, except if you're stupid, then it is better that you be another one.
I Amiga
- www.WinUAEspanol.com
I know, my english is very bad, sorry...
Pingui
Re: Forum Online
Post by Pingui »
Hello again and I'm sorry for my double posting.
The installation has been without any problem but I am realizing that both registered people and visitors enter the different parts of the forum the Forum Online extension does not mark the visit, these are always at 0.
Should not all the visits made to the different parts of the forum be recorded?
As always, thanks for everything.
Re: Forum Online
It's a crap ext i had it a while back and made changes to it also i landed up deleting it :rolling: load of rubbish.
Pingui
Re: Forum Online
Post by Pingui »
The idea of the extension is interesting but your answer has made it very clear to me :rolling:
I'll take her out of the way then ...
Re: Forum Online
I'll ask about it the original author of the extension. :thumbup:
Re: Forum Online
You better not ask evilsystem then as he is NOT the original author.
A lot tof the stuff your getting from here https://amxx-bg.info/ is stolen :rolling: heck i know they have had to remove most of your posts giving away my stuff. :rolling:
Why do you feel the need to post other sites ext's there ? the aim is to make them and have ppl join this site not grat the files from other sites example https://amxx-bg.info/viewtopic.php?f=67&t=7082
be so funny if all exts needed a key :rolling: :rolling:
Re: Forum Online
As you know, I no longer post your extensions in the amx , and if you think most things are stolen there then you will need to talk to the forum administrators. The purpose is not for more people to come in, it's just to say who authored the extension so you don't say I stole it or something because I can't do extensions :roll:
Re: Forum Online
First post updated with the correct author bb3mobi and his site https://www.phpbbguru.net and also files.
Re: Forum Online
But .yml check he says - bb3mobi / total_online_forum contains invalid characters and
Find services.yml
services:
    bb3mobi.total_online_forum.listener:
        class: bb3mobi\total_online_forum\event\listener
        arguments:
            - @user
            - @config
            - @dbal.conn
            - @cache.driver
        tags:
            - { name: event.listener }
Replace with
services:
        arguments:
            - '@user'
            - '@config'
            - '@dbal.conn'
            - '@cache.driver'
        tags:
Hamidouki-dz
Re: Forum Online
Post by Hamidouki-dz »
Work on 3.2.7 and 3.3.9 ?
Re: Forum Online
Yes work fine with phpBB 3.3.9
phpBB: 3.3.15 | PHP: 8.4
