3.2.x Extensions Database 3.2 / 3.3Disable Cache
Disable Cache
Extension Name: Disable Cache
Problems with counting downloads in chrome and firefox?
Disable cache for downloading attachments form you forum.
Clear broweser cache after installing this extension.
Requires viewtopic.php?f=66&t=3644
Changed code for 3.2.8
none
  2. Unzip the downloaded release, and change the name of the folder to `disablecache`.
  4. Copy the `disablecache` folder to `/ext/dmzx/` if done correctly, you'll have the main extension class at
    (your forum root)/ext/dmzx/disablecache/composer.json
  6. Look for `Disable Cache` under the Disabled Extensions list, and click its `Enable` link.
Re: Disable Cache
I have a question?
Does this affect all board members cache?
Re: Disable Cache
Yes
Re: Disable Cache
Installed in anticipation of download limit ext :)
Re: Disable Cache
clight77 wrote: 05 Jul 2019, 15:40 I have a question?
does it work with Opera browser?
Re: Disable Cache
Re: Disable Cache
