3.2.x Extensions Database 3.2 / 3.3Download Database
Download Database
Extension Name: Download Database
Will add download button in ACP for downloading database.
User id 2 can only see download button and can download the database.
Requires Editor extension
Download Database v1.0.0
  2. Unzip the downloaded release, and change the name of the folder to `downloaddatabase`.
  4. Copy the `downloaddatabase` folder to `/ext/dmzx/` if done correctly, you'll have the main extension class at
    (your forum root)/ext/dmzx/downloaddatabase/composer.json
  6. Look for `Download Database` under the Disabled Extensions list, and click its `Enable` link.
Re: Download Database
When i install this ext suspect that stop deleting backup thro the acp,also can't start restore board from backup in the ACP
It has no option to delete just download.
I know,but maybe need to make changes,so that not to stop restoring and deleting backup files
Fast_Eddie
Post by Fast_Eddie »
Can't you already do this by ticking the store file local button ? :wtf: :whistl:
:beers: Retirement 2024!
No you cant since 3.2.7
Wil
Post by Wil »
I have done an update to 3.2.8.
Now I no longer see the button to download
Ik heb een update gedaan naar 3.2.8.
Nu zie ik de knop om te downloaden niet meer
Regards,
Wil
Sorry my English is not my basic language
Did you reinstall the extension?
This ext alters the core files of phpbb so after any phpbb update you will always need to reinstall the ext.
tamarin
Post by tamarin »
Hi there.
I have activated this extension (editor extension too).
But it does not indicate anything to me. :wall:
Can you help me please?
tamarin wrote: 10 Oct 2019, 04:25 Hi there.
did you see the image in 1st post?
it says download database,so you need to see "download" button where you make backups :thumbup:
ivailo95 wrote: 10 Oct 2019, 09:16
I did check on 3.2.8 and still working ok.
NAPWR Online
Post by NAPWR »
Works well and updated here also on 3.2.8, thanks :tumbsyes: :dance: :ninja: :music:
My name is Dave I, and all things are out there, and we are in here :mml:
tamarin
Post by tamarin »
- See please my attachment.
tamarin wrote: 10 Oct 2019, 22:31
Are u user_id 2?
