3.2.x Extensions Database 3.2 / 3.3Cookie Settings
Cookie Settings
Extension Name: Cookie Settings
This extension adds some more options to the Cookie settings.
dmzx/Cookie-Settings
Cookie Settings v1.0.0
  2. Unzip the downloaded release, and change the name of the folder to `cookiesettings`.
  4. Copy the `cookiesettings` folder to `/ext/dmzx/` if done correctly, you'll have the main extension class at
    (your forum root)/ext/dmzx/cookiesettings/composer.json
  6. Look for `Cookie Settings` under the Disabled Extensions list, and click its `Enable` link.
eunaumtenhoid
Re: Cookie Settings
Post by eunaumtenhoid »
NICE work
* Brazilian Portuguese translation by eunaumtenhoid (c) 2017 [ver 1.0.0]
https://github.com/phpBBTraducoes/cookiesettings
Re: Cookie Settings
Lets slim the bar down on desktops but normal size on mobiles.
Your need to add this code into a css file or if you use cssmagic then add this code into the css file.
/* Cookie css
.cc-window {
    height: 28px;
@media only screen and (max-width: 700px), only screen and (max-device-width: 700px) {
.cc-window {
       height: auto;
/* Cookie css end
so bigger screens get the slim bar and any screen under 700px gets the full bar.
Live demo: Here
Re: Cookie Settings
eunaumtenhoid wrote: 11 Dec 2017, 22:26 NICE work
Added to download :thumbup:
Re: Cookie Settings
Cookie Settings_1.0.0-Slovenian.zip
