3.2.x Extensions Database 3.2 / 3.3Fa Fa roll effect 3.2.x
Extension Name: Fa Fa roll effect
Author: dmzx & martin
Roll effect on fa fa icons on hover.
dmzx/Fa-Fa-roll-effect
Fa Fa roll effect v1.0.0
  2. Unzip the downloaded release, and change the name of the folder to `fafarolleffect`.
  4. Copy the `fafarolleffect` folder to `/ext/dmzx/` if done correctly, you'll have the main extension class at
    (your forum root)/ext/dmzx/fafarolleffect/composer.json
  6. Look for `Fa Fa roll effect` under the Disabled Extensions list, and click its `Enable` link.
lopoto
Re: Fa Fa roll effect 3.2.x
Post by lopoto »
Nice :eyes2:
cisco007
Post by cisco007 »
Looks great!
testing1
Post by testing1 »
I have installed this but I do not get all the things rotating that you do here only a some of the forum icons rotate none of the smilies or or other stuff rotate why? or is this just a cut down version release?
testing1 wrote: 10 May 2017, 04:25 I have installed this but I do not get all the things rotating that you do here only a some of the forum icons rotate none of the smilies or or other stuff rotate why? or is this just a cut down version release?
The rotating avatar and some other stuff is done with cssmagic:
viewtopic.php?f=49&t=905&hilit=magic
testing1
Post by testing1 »
Ya added that all it does is move topic titles and user avatars nothing else- no rotating smilies or rotating pics in topics
testing1 wrote: 10 May 2017, 22:55 ya added that all it does is move topic titles and user avatars nothing else- no rotating smilies or rotating pics in topics
Take a look @ Dmzx his cssmagic css file
ext/martin/cssmagic/styles/prosilver/theme/cssmagic.css
.forum-image:hover {
    cursor: default;
    transform: rotate(360deg);
    transition: all 0.9s ease-in-out 0s;
.avatar:hover {
    cursor: default;
.smilies:hover {
    cursor: default;
img:hover {
    cursor: default;
testing1
Post by testing1 »
:rolling: OH my god that is awesome it works and is just too funny many thanks for that code!
Engelchen
Post by Engelchen »
Thank you :thumbup:
BBBenj
Post by BBBenj »
Thank you.
Works fine in 3.3.5
BBBenj wrote: 08 Jan 2022, 21:20 Thank you.
Works fine in 3.3.5
At 3.3.7 also
Sylver Cheetah 53
Post by Sylver Cheetah 53 »
What's this? A little bit info, please!
Free your mind!
Sylver Cheetah 53
It is very cool. Great work!
Sylver Cheetah 53
When I hover an icon, it rolls and it is cool. But does not show the mouse pointer anymore.
Any chance of a fix?
