Extensions Database 3.2 / 3.3 ⇒ 3.3.x Button index
3.2.x & 3.3.x
15 given 2
Button index
Extension Name: Button index
Author: dmzx & martin & Sniper_E
Adds Button index to your forum index for link(URL) or can be used for quick links to forum.
[travis]dmzx/Button-index[/travis]
- Added option to enable styled button.
- Added option to enable fade between ucp and site buttons.
- Added option to enable images or icons in site buttons.
- Added option upload images in ACP.
- Added option to change directory in ACP.
- Added code to see buttons UCP when extensions are enabled, mchat/youtubegalley/imageupload/ect.
- Added Authors in footer.
- Added Logs in admin controller / language file.
- Changed layout of ACP.
- Various code updates.
Code update
Code update
  2. Unzip the downloaded release, and change the name of the folder to `buttonindex`.
  4. Copy the `buttonindex` folder to `/ext/dmzx/` if done correctly, you'll have the main extension class at
    (your forum root)/ext/dmzx/buttonindex/composer.json
  6. Look for `Button index` under the Disabled Extensions list, and click its `Enable` link.
1 given 2
Re: Button index
Re: Button index
German language file [DE]
Joost
Re: Button index
Post by Joost »
As i click on the settings, give my forum this error.
Fatal error: Uncaught phpbb\exception\version_check_exception: Connection refused in /home/vhosts/hpmagicworld.nl/httpdocs/phpbb/version_helper.php:266 Stack trace: #0 /home/vhosts/hpmagicworld.nl/httpdocs/phpbb/version_helper.php(231): phpbb\version_helper->get_versions(true, false) #1 /home/vhosts/hpmagicworld.nl/httpdocs/phpbb/version_helper.php(210): phpbb\version_helper->get_versions_matching_stability(true, false) #2 /home/vhosts/hpmagicworld.nl/httpdocs/ext/dmzx/buttonindex/includes/version_check.php(67): phpbb\version_helper->get_suggested_updates(true) #3 /home/vhosts/hpmagicworld.nl/httpdocs/ext/dmzx/buttonindex/controller/admin_controller.php(168): dmzx\buttonindex\includes\version_check->check() #4 /home/vhosts/hpmagicworld.nl/httpdocs/ext/dmzx/buttonindex/acp/acp_buttonindex_module.php(34): dmzx\buttonindex\controller\admin_controller->display_options() #5 /home/vhosts/hpmagicworld.nl/httpdocs/includes/functions_module.php(676): dmzx\buttonindex\acp\acp_buttonindex_module->main('\\dmzx\\buttonind...', 'settin in /home/vhosts/hpmagicworld.nl/httpdocs/phpbb/version_helper.php on line 266
15 given 2
Re: Button index
Joost
Re: Button index
Post by Joost »
dmzx wrote: 13 Feb 2017, 23:37First post updated
Thank you,
Can i set this on the footer ? And on all pages ? :eusa_dance:
1 given 2
Re: Button index
It uses an event that only shows on the index but you can add other events with just the buttons code in and it will show where ever the new event you add is ment to be.
1 given 2
Re: Button index
Like this ?
Joost
Re: Button index
Post by Joost »
martin wrote: 14 Feb 2017, 19:57Like this ?1.png
Yes, that's is what i mean! :eusa_dance:
opoesiemen
Re: Button index
Post by opoesiemen »
Nice extension, it would be great if you develop the same extension for 3.1!
PepeFJR
Re: Button index
Post by PepeFJR »
Very nice!!! But is it possible to implement (in settings menu of extension) to be able to choose not only the links on index page but also in viewforum page?
Thank you in advance!! I love all your extensions!!
[ Post made via iPad ] Image
15 given 2
Re: Button index
PepeFJR wrote: 25 Mar 2017, 10:29 Very nice!!! But is it possible to implement (in settings menu of extension) to be able to choose not only the links on index page but also in viewforum page?
I will check this option, is added to the to do list :wink:
PepeFJR
Re: Button index
Post by PepeFJR »
dmzx wrote: 25 Mar 2017, 10:31
Thank you very much!! You are great!!
Re: Button index
Running on 3.1.10 ?
:whistl:
Galixte de EzCom
Re: Button index
Post by Galixte de EzCom »
Hi dmzx,
it could be better to add the possibility to customize the Font Awesome icon for each button.
Moreover, it could be better to have the choice between open the link in an new tab or on the same tab.
FRENCH translation submitted on GitHub: https://github.com/dmzx/Button-index/pull/2 and available on EzCom Community.
Communauté EzCom
Image « Traductions d’extensions & styles pour phpBB 3.1.x & 3.2.x ».
