3.2 & 3.3 Extensions Database 3.2 / 3.3Milestones
Milestones
Extension Name: Milestones
Adds phpBB Milestones to your forum.
phpBB version: >=3.2.0-a1
- Code cleanup.
- Twig update.
Code update
Added ACP option to add more milestones
Code update
Milestones v1.0.4
  2. Unzip the downloaded release, and change the name of the folder to `milestones`.
  4. Copy the `milestones` folder to `/ext/dmzx/` if done correctly, you'll have the main extension class at
    (your forum root)/ext/dmzx/milestones/composer.json
  6. Look for `Milestones` under the Disabled Extensions list, and click its `Enable` link.
zardos
Re: Milestones
Post by zardos »
Great ext, Thanks :thumbup: :thumbup:
Re: Milestones
zardos
Re: Milestones
Post by zardos »
:thumbup: :thumbup:
iorG19
Re: Milestones
Post by iorG19 »
How to view/expanded the block by default ??? It's there possible to show anywhere else than (footer) board index ? For example in to a custom page ?
Re: Milestones
The toggle will work any where if you wrap your code in the toggle code. :whistl:
iorG19
Re: Milestones
Post by iorG19 »
martin wrote: 20 Dec 2016, 21:16 The toggle will work any where if you wrap your code in the toggle code. :whistl:
i don't know if the sorted order is here:
<script>
	var repositories = [
	<!-- BEGIN milestones -->
	{"id": "{milestones.MILESTONES_TEXT}", "path": "{milestones.MILESTONES}"},
	<!-- END milestones -->
	var showText = '{LA_MILESTONES_VIEW}';
	var hideText = '{LA_MILESTONES_HIDE}';
</script>
<script>
</script>
or here: toogle.js
jQuery(function(){$(document).ready(function(){$('.toggle').prev().append(' <a href="#" class="toggleLink">'+showText+'</a>');$('.toggle').prev().data('is_visible',true);$('.toggle').hide();$('a.toggleLink').click(function(){$(this).data('is_visible',!$(this).data('is_visible'));$(this).html((!$(this).data('is_visible'))?showText:hideText);$(this).parent().next('.toggle').toggle(500);return false;});});});
In line find This is a partial match of a line for in-line operations
In line replace with
.append(' <a href="#" class="toggleLink">'+showText+'</a>');$('.toggle').prev().data('is_visible',false)
:wall:
Re: Milestones
Re: Milestones
German language files [DE]
kaspir
Re: Milestones
Post by kaspir »
Can this ext be used without a github account? Basically used for private site milestones?
Check out phpBB contributions & extension downloads. :P
Re: Milestones
kaspir wrote: 03 Feb 2017, 12:49 Can this ext be used without a github account? Basically used for private site milestones?
It takes the data from github milestones.
To show them you dont need an account on github or do you mean something else?
kaspir
Re: Milestones
Post by kaspir »
dmzx wrote: 03 Feb 2017, 17:29
Thanks D! You answered it.
Re: Milestones
This extension works on my 3.2.1 test board.
But on my live board, it wont show.. Enabled, cleared cache.. nothings works.
Milestone extension totally invisible :eyes2:
Tried on all styles..
:wall:
eunaumtenhoid
Re: Milestones
Post by eunaumtenhoid »
* Brazilian Portuguese translation by eunaumtenhoid (c) 2018 [ver 1.0.2]
https://github.com/phpBBTraducoes/milestones
Re: Milestones
This extension is not working when this extension is enabled: dmzx/newestmembers
Can you please take a look at that?
:oops:
