3.1.x Extensions DatabaseFavicon Animated
Favicon Animated
Extension Name: Favicon
Extension Version: 1.0.1
Author: Sniper_E
Extension Description: Inserts an animated.gif image in your browser's address bar.
For the browsers that do not support animated images a favicon.ico will show. Setup for ACP also.
favicon_1_0_1.zip
Installation: Copy contents from download to ext/sniper/favicon/ directory - Enable in ACP
Information: The favicon is supposed to be a set of 16x16, 32x32 and 48x48 pictures in ICO format.
You can find many .ico generators online to convert your image into a favicon.ico.
Use one frame from your animated.gif image you are using to create a favicon.ico file.
The animated image and favicon are located in ext/sniper/favicon/images/ directory.
Simply replace the images with your own for your site.
Enjoy!
This topic has 11 replies
