3.2 & 3.3 Extensions Database 3.2 / 3.3Notify upon reply
Notify upon reply
Extension Name: Notify upon reply
This extension add notify upon reply as default and a switch in UCP so goups/members can switch it off.
Admin can set permission for this.
Code cleanup.
Code update.
Dropped 3.1.x support.
Updated composer.json.
  2. Unzip the downloaded release, and change the name of the folder to `notifyuponreply`.
  4. Copy the `notifyuponreply` folder to `/ext/dmzx/` if done correctly, you'll have the main extension class at
    (your forum root)/ext/dmzx/notifyuponreply/composer.json
  6. Look for `Notify upon reply` under the Disabled Extensions list, and click its `Enable` link.
zardos
Re: Notify upon reply
Post by zardos »
Thank you :thumbup:
khurrammunawar
Post by khurrammunawar »
Is it compatible with 3.1.9 and 3.1.10
Tarantino
Post by Tarantino »
I don't understand this extension.
On a fresh phpbb we already have on UCP an option:
"Notify me upon replies by default".
Isn't this redundant? :wtf:
khurrammunawar
Yes you are right.
but that option is not enabled by default.
but this extension will enable the notification option enable by default
caju
Post by caju »
Does this extension works on 3.2? Is there a way to make this option the default in 3.2?
Kind regards,
Works here dont it.
caju
Post by caju »
Thanks, Martin :)
[ Post made via iPhone ] Image
Tarantino
Post by Tarantino »
This will enable the option for all users, or just for new registrations?
All users.
kushcat
    Windows 10 Edge
Post by kushcat »
Hi i installed the prime notify extension too and just wanted to make sure that they wont cause problems with each other
kushcat wrote: 14 Apr 2025, 05:20 hi i installed the prime notify extension too and just wanted to make sure that they wont cause problems with each other
Not known conflict, if so please report them here.
