Posts: 6476 Joined: 13 Jan 2014, 21:45
Post
by dmzx » 01 Mar 2016, 11:32
Extension Name: Username BBCode 3.2.x
Username BBCode with Group Colours.
Select Username:
Selected:
Output:
Download the latest release.
Unzip the downloaded release, and change the name of the folder to `username `.
In the `ext ` directory of your phpBB board, create a new directory named `dmzx ` (if it does not already exist).
Copy the `username ` folder to `/ext/dmzx/ ` if done correctly, you'll have the main extension class at
(your forum root)/ext/dmzx/username/composer.json
Look for `Username BBCode ` under the Disabled Extensions list, and click its `Enable ` link.
Posts: 356 Joined: 02 Nov 2014, 21:25
Post
by Jaantje » 02 Mar 2016, 20:10
dmzx Thanx U
Username BBCode 3.2.x - Dutch translation.zip
awr
Posts: 55 Joined: 13 Mar 2015, 08:50
Post
by awr » 14 Jan 2017, 00:50
Turkish Language Pack
tr.zip
infspirit
Posts: 25 Joined: 13 Sep 2015, 20:50
Post
by infspirit » 14 Jan 2017, 12:56
Spanish Language Pack
Posts: 310 Joined: 06 Apr 2015, 18:04
Post
by Scanialady » 14 Jan 2017, 18:27
German language file
Funny
Posts: 126 Joined: 06 Mar 2017, 16:39
Post
by Funny » 06 Mar 2017, 22:45
Hallo
Thank you for this extention
seacoast
Posts: 159 Joined: 28 Aug 2017, 19:58
Post
by seacoast » 15 Sep 2017, 11:32
I can't figure out how to get the font color to change.
This is what I have for HTML replacement.
<a class="username-coloured" style="color:lime;font-weight:{IDENTIFIER};" href="./memberlist.php?mode=viewprofile&u={NUMBER}">{TEXT}</a>
It's probably obvious but I can't see it.
boldherri
Posts: 46 Joined: 31 May 2018, 15:28
Post
by boldherri » 02 Jun 2018, 18:10
The extension works fine, the only thing is that notifications no arrive when you're tagged, so how do i know that I've been tagged?
this is a great lack
Post
by dmzx » 14 Jun 2018, 10:23
boldherri wrote: 02 Jun 2018, 18:10
the extension works fine, the only thing is that notifications no arrive when you're tagged, so how do i know that I've been tagged?
That is not the purpose of this extension only username bbcode.
merlinkv
Posts: 16 Joined: 22 Nov 2015, 10:32
Post
by merlinkv » 05 Dec 2018, 12:51
I can't get it to work under phpBB 3.2.4 ... Anyone have the same issue?
Post
by dmzx » 05 Feb 2019, 09:42
merlinkv wrote: 05 Dec 2018, 12:51
works perfect out of the box, what style do you use?
merlinkv
Post
by merlinkv » 05 Feb 2019, 11:13
I'm using ProSilver SE.
Post
by dmzx » 05 Feb 2019, 11:16
merlinkv wrote: 05 Feb 2019, 11:13
Do you see the selectbox?
if not check if your style
uses posting_editor_buttons_custom_tags_before as an event.
otherwise post image of what you see.
tamarin
Posts: 72 Joined: 15 Mar 2015, 01:07
Post
by tamarin » 26 Oct 2019, 00:10
Thanks for the extension.
I have a problem: The function to select the user indicates, but I can not click.
Can you help me please?
Posts: 1160 Joined: 14 Oct 2014, 19:01
Post
by Sniper_E » 26 Oct 2019, 00:35
This bbcode enters your username,
tamarin with your group color and profile link. This is a test.
