3.2.x Extensions DatabaseMember time counter 3.2.x
Extension Name: Member time counter 3.2.x
phpBB 3.2 extension that will display member time counter in profile.
Member time counter 3.2.x v1.0.1
  2. Unzip the downloaded release, and change the name of the folder to `membertimecounter`.
  4. Copy the `membertimecounter` folder to `/ext/dmzx/` if done correctly, you'll have the main extension class at
    (your forum root)/ext/dmzx/membertimecounter/composer.json
  6. Look for `Member time counter` under the Disabled Extensions list, and click its `Enable` link.
This topic has 17 replies
