3.1 & 3.2 Extensions Database 3.1 / 3.2Travis BBcode
Travis BBcode
Extension Name: Travis BBcode
This Extension will add a new BBcode for Travis Build Status.
dmzx/Travis-BBcode
Code cleanup
Remove delete bbcode
Travis BBcode v1.0.1
  2. Unzip the downloaded release, and change the name of the folder to `travisbbcode`.
  4. Copy the `travisbbcode` folder to `/ext/dmzx/` if done correctly, you'll have the main extension class at
    (your forum root)/ext/dmzx/travisbbcode/composer.json
  6. Look for `Travis BBcode` under the Disabled Extensions list, and click its `Enable` link.
Re: Travis BBcode
nelflucifer
Re: Travis BBcode
Post by nelflucifer »
dmzx wrote: 13 Dec 2015, 00:39First post updated
What is this extension? Can't understand the meaning...
English Forums
Re: Travis BBcode
nelflucifer wrote: 04 Jan 2016, 16:42
Its for Travis badge, just for software releases check.
taledus
Re: Travis BBcode
Post by taledus »
Does this extension still work? I installed it a few days ago and just now getting around to testing it out. I have tried:
[travis]build/passing[/travis]
as well as several examples on the first post, but it shows nothing on the screen. So I turned it off, then I tried to delete the data and I get:
A migration is invalid. A custom callable function could not be called.
So I tried deleting the folder, clearing the server cache, reinstalling this mod, but get the same results...
Even tried it here but it does not display:-> build/passing <-
What did I mess up?
Re: Travis BBcode
This will only work if you have an travis account, usually used for programmers.
taledus
Re: Travis BBcode
Post by taledus »
Oh...I have github, but I don't have anything posted on there because I keep most of my stuff on Visual Studio Online.
I like these tags for my projects, but I don't like the idea of having to use http://shields.io/ each time I want to make a tag that I plan to use for a project.
Maybe I will figure out how to make something like this with just css and bb codes.
phpbbexst
Re: Travis BBcode
Post by phpbbexst »
Hello i have a problem to uninstall this extension
in practice when I click on Delete date does not uninstall it, here error text
Something went wrong during the request and an exception was thrown. The changes made before the error occurred were reversed to the best of our abilities, but you should check the board for errors.
Re: Travis BBcode
phpbbexst wrote: 20 Nov 2016, 06:19 hello i have a problem to uninstall this extension
Re-download and upload the files again, then disable and delete data in ACP.
