3.1.x Extensions Database 3.1 / 3.2Total private messages
Extension Name: Total private messages
Special Thanks to: martin
This extension shows total private messages on index.
dmzx/Total-private-messages
downloadsystemcat?id=38
  2. Unzip the downloaded release, and change the name of the folder to `totalpms`.
  4. Copy the `totalpms` folder to `/ext/dmzx/` if done correctly, you'll have the main extension class at (your forum root)/ext/dmzx/totalpms/composer.json
  6. Look for `Total private messages` under the Disabled Extensions list, and click its `Enable` link.
