Re: Image Upload
Hello thanks for your answer.
chmod where?
thanks Jan
Re: Image Upload
In File imageupload.php line 210 and 211 permission is already 0644 yet.
another one,too
bye jan
spinecki
Re: Image Upload
Post by spinecki »
Yes, but look in the filemanager after the upload. Somehow uploaded files are 0600, instead of 0644. This is why you got error.
Re: Image Upload
spinecki wrote: 17 Feb 2017, 16:27 Yes, but look in the filemanager after the upload. Somehow uploaded files are 0600, instead of 0644. This is why you got error.
thanks
all uploaded Files have got permission 0104.
but how could I change for all Users?
bye Jan
Edit
if I change in filezilla the permission of the folder "Files" from 0755 to 0777 same Problem.
changed all folders to 0777 same problem.
Upload with Smartphone and Chrome same problem
Upload with PC and IE11 same problem
Upload a picture with filezilla permission 0644.
Re: Image Upload
Why are you playing with file perms ? if your host was any good then you would not ever need to touch them.
Re: Image Upload
:buigen: n i c e
OK once again.
with filezilla permission : 0644
with Imageupload: 0104
With the same picture.
why ?
changing Host? :rolling:
DKBjorn
Re: Image Upload
Post by DKBjorn »
DKBjorn wrote: 17 Feb 2017, 14:09 are there plan for make multiple image upload....?
Is it diffficult to implent...?
No one can help...?
Re: Image Upload
DKBjorn wrote: 17 Feb 2017, 22:55
No one can help...?
For now only single line upload is possible, I need to check if possible multiple upload is possible.
DKBjorn
Re: Image Upload
Post by DKBjorn »
dmzx wrote: 17 Feb 2017, 23:41
No one can help...?
Okay... hope it could be possible.....
Re: Image Upload
dmzx wrote: 12 Feb 2017, 09:05
killfrenzy wrote: 12 Feb 2017, 05:51 Ive checked the ftp file ext/dmzx/imageupload/files the permission is set in 600 then I've changed to 644 then the image shows. How to set it automatically? Or I've something I missed in this extension?
How did you upload the extension with upload extension or ftp?
Folder must be indeed 0644, all files will be automatic cmod 0644 when you upload them.
see for ref:
https://github.com/dmzx/Image-Upload/bl ... #L210-L211
if extension change permission to 0644 automatic why the permission is 0104 if I upload a picture with imageload 1.03 ? permission is 0644 if I upload the same picture with ftp.
Hippie459MN
Re: Image Upload
Post by Hippie459MN »
Just thought I would let you know, I just installed this on a 3.2.0 test board on my server, at first it was not working. I had a missing submit button, that was fixed by disabling the Form Creator ext, but the images uploaded here work just fine (chmod 0644) and the extension works just perfect for me. Im guessing if your images permissions are being changed from 0644, then its something with your server/hosting compnay. Both on my server and on a localhost it works here.
Now about that missing submit button when Form Creator is enabled.
"I went outside once. The graphics sucked but the game play was ok."
Re: Image Upload
Hippie459MN wrote: 21 Feb 2017, 18:19 Now about that missing submit button when Form Creator is enabled.
Try download the latest file of Form Creator.
Re: Image Upload
Hello .... my problem is solved now.
in imagecontroller.php I have changed in row 210 + 211 the permission from 0644 to 1050 and now it works.
now i can use Imageupload
:P
Edit:
I changed permission at imagecontroller.php from 0644 to 0755 I could see picture permission 0325 in filezilla.
If I Change from 0755 to 0999 I see 0600 in filezilla.
:wtf:
qnexo
Re: Image Upload
Post by qnexo »
I do not know if it comes from me or my file but I still have the same problem
I just looked at the whole subject and I still did not understand
my website
Re: Image Upload
Try to change permission in line 210 and 211 up to 0655 or 0700,....
save file
clear cache
try again and look at permission in ftp.
:coffee:
