3.2 & 3.3 Extensions Database 3.2 / 3.3 ⇒ Email List
- Donator
Re: Email List
Will this get a 3.2 update?
Because it shows a white page in 3.2
Re: Email List
Works on my 3.2 with php7 but could do with a small update for fafa
3.1 and 3.2
- Donator
Re: Email List
Perfect! Thank you!martin wrote: 28 Feb 2017, 15:38 Works on my 3.2 with php7 but could do with a small update for fafa 1.png
3.1 and 3.2 dmzx_emaillist_1_0_2.zip
<!-- IF S_EMAIL_LIST -->
<li>
<a href="{U_EMAIL_LIST}" role="menuitem">
<i class="icon fa-envelope fa-fw icon-orange" aria-hidden="true"></i><span>{L_EMAIL_LIST}</span>
</a>
</li>
<!-- ENDIF --> You do not have the required permissions to view the files attached to this post! Maybe your post count is too low.
Re: Email List
Should be
to be responsive also both phpbb versions
<li <!-- IF not PHPBB_IS_32 -->class="small-icon icon-members"<!-- ENDIF --> data-last-responsive="true">
<a href="{U_EMAIL_LIST}" title="{L_EMAIL_LIST}" role="menuitem">
<!-- IF PHPBB_IS_32 --><i class="fa fa-envelope" aria-hidden="true"></i><!-- ENDIF -->
</a>
</li>
<!-- ENDIF -->-
- Donator
Re: Email List
Ow I thought I can remove the code for 3.1 ?
Changed
Changed
Re: Email List
Hello.martin wrote: 28 Feb 2017, 17:03 Should be
to be responsive also both phpbb versionsCode: Select all
<!-- IF S_EMAIL_LIST --> <li <!-- IF not PHPBB_IS_32 -->class="small-icon icon-members"<!-- ENDIF --> data-last-responsive="true"> <a href="{U_EMAIL_LIST}" title="{L_EMAIL_LIST}" role="menuitem"> <!-- IF PHPBB_IS_32 --><i class="fa fa-envelope" aria-hidden="true"></i><!-- ENDIF --> <span>{L_EMAIL_LIST}</span> </a> </li> <!-- ENDIF -->
Which file needs to be changed?
where i need to be put in?
[ Post made via Android ]
Re: Email List
You dont its in the ext i uploaded.
Re: Email List
You can but why make extra work if your using phpbb 3.2 then all 3.1 code will be ignored.
Re: Email List
Sorry .... email list looks like this in my forum...
its only for 3.2 the orange letter icon?
bye Jan
bye Jan
Re: Email List
Its 3.1 and 3.2 it detects your version and will use the icon that matches your phpbb.
Re: Email List
Orange letter based in 3.2?
Re: Email List
Just use the ext i posted and dont edit any thing you dont need too the ext will show what its ment to show
Dont use this line
<i class="icon fa-envelope fa-fw icon-orange" aria-hidden="true"></i><You do not have the required permissions to view the files attached to this post! Maybe your post count is too low.
Re: Email List
Ok ... I understand your warning "not again" ...
I do not change anything
Nevertheless many thanks
testingground
Re: Email List
Any way of making this viewable for mods as well?
