3.1 & 3.2 Extensions Database 3.1 / 3.2Support Ticket
TWEagle
Re: Support Ticket
Post by TWEagle »
Sprinklestar wrote: 27 Jan 2016, 09:21
TWEagle wrote: 23 Jan 2016, 13:28 is there also an add attachment part in??
You use a forum for it so it depends on the permission you add to the forum so the answer would be yes
but is it possible to incldue it
I know it is a permission
but now you have attachment not included in the "support ticket" but I wnat to include it into the support ticket
yaooke
Re: Support Ticket
Post by yaooke »
I enabled it in the extension manager but I'm not seeing it anywhere.
I can't find this anywhere
It's not showing under ''Extensions'' in the ACP.
I have phpBB 3.1.6
Sprinklestar
Re: Support Ticket
Post by Sprinklestar »
If you create a new forum or you edit an existing one you get the option to enable or disable it, its a form of baked in template for your forum
*nl*
als je een nieuw forum aanmaakt of je bwerkt een bestaand forum dan zie je het pas, er is geen extra admin pagina voor of zo, het staat in het rijtje als je een forum aanmaakt, het is een soort van vooringevoegde template met standaard vragen
yaooke
Re: Support Ticket
Post by yaooke »
Sprinklestar wrote: 08 Mar 2016, 15:04 if you create a new forum or you edit an existing one you get the option to enable or disable it, its a form of baked in template for your forum
*nl*
Thanks, what a hazard
Nice extension though. Just what I was looking for.
Joost
Re: Support Ticket
Post by Joost »
Does anyone have for me the Dutch translations for me, please? :whistl:
Musiker15
Re: Support Ticket
Post by Musiker15 »
German Translation
supportticket_1_0_1_deutsch.zip
I'm from Germany so my English is not the best...
________________________________________________________________
Re: Support Ticket
Musiker15 wrote: 16 Nov 2016, 20:48 German Translation
    Windows 7 Internet Explorer
Re: Support Ticket
Hello.
Thanks for german file - very nice :buigen:
But i have a problem.
I want to Change the row "phpbbversion"
The row descreption could i Change - no Problem.
But if i want copy the first row under the first it doesn´t work.
I have try to change the files:
posting_editor_subject_after.html
common.php (de)
listener.php
My wish:
for my Forum i Need :
Four textfields "size="45" maxlength="20"
Two fields with yes or no
two fields "rows="10" cols="45" class="inputbox""
All other fields not nessseary.
Who could help me , is very important!
Thank you very much.
Bye Jan (from Germany :wave: )
Re: Support Ticket
Hello.
Who could create a Support ticket Extension which appears on the mainpage ???
it should locate between mchat and active Topics
my Vision:
heading name
5 Input text boxes maximum length 20 characters
3 Input text boxes 10 rows maximum length 500 characters
1 function to upload data and Pictures
1 function to select a forum directory which ticket create in
please say me your price , i pay :wave:
i Need this for me new forum to answers technical questions about all cars
who couldhelp me ? :whistl:
phpbb Version 3.1.10
---- EDIT :
I´ve edit he php files and this is the result:
what make i wrong?
In the first Change i have try to reduce the rows....but it still appears (big letters in english)
All german changes are correct.
----EDIT_2:
Ok i clear Cookies , and clear workdata and i deactived and reactived the Support ticket
...and now result:
the choise field with yes or no doesn´t appear :wall:
ok... next try
----Last edit:
Nice i´m ready!!!!
MOD done.
:eusa_dance: :eusa_dance:
TWEagle
Re: Support Ticket
Post by TWEagle »
Does this one also support version 3.2.X from phpBB?
Re: Support Ticket
TWEagle wrote: 12 Feb 2017, 19:03 Does this one also support version 3.2.X from phpBB?
Yes will work.
I will update it also soon for official 3.1 & 3.2 release.
Re: Support Ticket
This tool is very versatile and arbitrarily expandable.
A building block system would be a good solution like form creator.
bye Jan
Re: Support Ticket
jan_2017 wrote: 12 Feb 2017, 19:57 This tool is very versatile and arbitrarily expandable.
Will look into this.
Re: Support Ticket
Wow :mml: :tumbsyes:
Could you put in the first topic any screenshots at the new changes please?
bye Jan
pedala
Re: Support Ticket
Post by pedala »
Anyone can help me, this extension is enable, but cant see this
Support Ticket
