3.1 & 3.2 Extensions Database 3.1 / 3.2Posting reset button
Extension Name: Posting reset button
Displays reset and cancel button in posting buttons.
Reset => Clears the text field.
Cancel => Will return to Topic.
dmzx/Posting-reset-button
Update code, validation version.
Update code for 3.1.6-RC1
Added memberlist_view_contact_before for contact / statistics in viewprofile
Added Cancel button
Extension Download: Download-linkPosting reset button v1.0.4 Installation:
  2. Unzip the downloaded release, and change the name of the folder to `postingresetbutton`.
  4. Copy the `postingresetbutton` folder to `/ext/dmzx/` if done correctly, you'll have the main extension class at
    (your forum root)/ext/dmzx/postingresetbutton/composer.json
  6. Look for `Posting reset button` under the Disabled Extensions list, and click its `Enable` link.
Re: Posting reset button
Works a treat installed ok :thumbup:
:thumbup: love it
dmzx thanx, works perfect :tumbsyes:
New Version see Update Version 1.0.1 · dmzx/Posting-reset-button@b87af6a · GitHub for changes.
Update to version 1.0.1.
Thanx dmzx works perfectimo :tumbsyes:
In case you installed Quickedit change the following to get the buttons back to work.
Open: ext\marc\quickedit\styles\prosilver\template\quickedit_body.html
<div class="panel bg2">
<div class="panel">
Purge the cache :wink:
Grtz dmzx
Update version see Update Version 1.0.2 · dmzx/Posting-reset-button@494bcd1 · GitHub for changes.
This ext breaks the pls wait edits of stokers if my version is the latest il post the fix for it.
YouTube Video
/ext/dmzx/postingresetbutton/styles/prosilver/template/event/posting_editor_message_after.html
replace the code in the file with this
Replace Replace the preceding lines with the following
<!-- IF not S_SHOW_DRAFTS and not $SIG_EDIT eq 1 -->
	<div class="panel">
		<div class="inner">
		<fieldset class="submit-buttons">
			{S_HIDDEN_ADDRESS_FIELD}
			{S_HIDDEN_FIELDS}
			<input type="submit" name="cancel" value="{L_CANCEL}" class="button2"  onclick="JavaScript:document.getElementById('buttons').style.display='none';document.getElementById('processingsub').style.display='block';" class="button1 default-submit-action" />&nbsp;
			<input type="reset" name="reset" value="{L_RESET}" class="button2" />&nbsp;
			<!-- IF S_HAS_DRAFTS --><input type="submit" accesskey="d" tabindex="8" name="load" value="{L_LOAD_DRAFT}" class="button2" onclick="JavaScript:document.getElementById('buttons').style.display='none';document.getElementById('processingload').style.display='block';load_draft = true;" />&nbsp; <!-- ENDIF -->
         <!-- IF S_SAVE_ALLOWED --><input type="submit" accesskey="k" tabindex="7" name="save" value="{L_SAVE_DRAFT}" onclick="JavaScript:document.getElementById('buttons').style.display='none';document.getElementById('processingsave').style.display='block';" class="button2" />&nbsp; <!-- ENDIF -->
         <input type="submit" tabindex="5" name="preview" value="{L_PREVIEW}" onclick="JavaScript:document.getElementById('buttons').style.display='none';document.getElementById('processingprev').style.display='block';<!-- IF not S_PRIVMSGS --> document.getElementById('postform').action += '#preview';<!-- ENDIF -->" class="button1" />&nbsp;
         <input type="submit" accesskey="s" tabindex="6" name="post" value="{L_SUBMIT}" onclick="JavaScript:document.getElementById('buttons').style.display='none';document.getElementById('processingsub').style.display='block';" class="button1 default-submit-action" />&nbsp;
      </fieldset>
      <fieldset id="processingload" class="submit-buttons" style="display:none;">
         <img src="{ROOT_PATH}images/loader.gif" width="16" height="16" alt="" style="margin-bottom:-5px; padding-right:10px;" /><input class="button1" type="button" value="<!-- IF S_IN_UCP -->{L_PM_LOAD_SENDING}<!-- ELSE -->{L_LOAD_SENDING}<!-- ENDIF -->" disabled="disabled" />&nbsp;
      </fieldset>
      <fieldset id="processingsave" class="submit-buttons" style="display:none;">
         <img src="{ROOT_PATH}images/loader.gif" width="16" height="16" alt="" style="margin-bottom:-5px; padding-right:10px;" /><input class="button1" type="button" value="<!-- IF S_IN_UCP -->{L_PM_DRAFT_SENDING}<!-- ELSE -->{L_DRAFT_SENDING}<!-- ENDIF -->" disabled="disabled" />&nbsp;
      </fieldset>
      <fieldset id="processingprev" class="submit-buttons" style="display:none;">
         <img src="{ROOT_PATH}images/loader.gif" width="16" height="16" alt="" style="margin-bottom:-5px; padding-right:10px;" /><input class="button1" type="button" value="<!-- IF S_IN_UCP -->{L_PM_PREVIEW_SENDING}<!-- ELSE -->{L_PREVIEW_SENDING}<!-- ENDIF -->" disabled="disabled" />&nbsp;
      </fieldset>
      <fieldset id="processingsub" class="submit-buttons" style="display:none;">
         <img src="{ROOT_PATH}images/loader.gif" width="16" height="16" alt="" style="margin-bottom:-5px; padding-right:10px;" /><input class="button1" type="button" value="<!-- IF S_IN_UCP -->{L_PM_POST_SENDING}<!-- ELSE -->{L_POST_SENDING}<!-- ENDIF -->" disabled="disabled" />&nbsp;
      </fieldset>
		</div>
	</div>
I also have a little problem with this extension.
I'm missing buttons in the arcade extension:
Missing button - JV-Arcade
Supply a test account as its login only.
martin wrote:supply a test account as its login only.
Login: Testaccount
Password: Testaccount
When you start a game, go back to arcade page and start te game again.
It tells you that you need to restart the game, but the button to restart is missing.
When I disable this extension, the button is there..
~ Arcadeplaats ~ - Arcade index
Ok this is with out me visiting your site open the file that contains the buttons for the arcade copy the button code to
you my need IF statment some thing like <!-- IF SCRIPT_NAME == "arcade" -->BUTTON CODE FOR ARCADE HERE<!-- ENDIF -->
Ok gonna try that tonight. If i find the code :rolling:
