Darkside2016
Re: Youtube Videos Gallery
Post by Darkside2016 »
Search user's videos is not searching a video
Search user's videos must be Show all videos from user
in video view
the serach thing was not working and brings me every time the error that the user not exist or has no access
in /conroler/youtubegallery.php search for this line
				'U_USER_VIDEOS' 	=> $this->helper->route('dmzx_youtubegallery_controller', array('mode' => 'user_videos' , 'user_id' => $this->user->data['user_id'])),
and replace with this one
				'U_USER_VIDEOS' 	=> $this->helper->route('dmzx_youtubegallery_controller', array('mode' => 'user_videos' , 'user_id' => $row['user_id'] , 'username' => $row['username'])),
after this changes, on the search site they will shown all videos from the user they posted them
now i need some help
on the search site where it is " Search user’s videos " i will show the username after that.
<h2>{L_USER_VIDEOS} <?php echo $_GET["username"]; ?></h2>
this line does not work
who can help on this ?
Darkside2016
I got it to work ......
what i have done ?
goto phpbb_root_path/config and open parameters.yml
    core.disable_super_globals: true
and change to
    core.disable_super_globals: false
this is importend to enable $_GET, $_POST and $_REQUEST ..... in templates......
then in ACP goto security and allow PHP in Templates
in the language files i have made some modifications
	'USER_VIDEOS_EXPLAIN'			=> 'Show all',
	'USER_VIDEOS'			=> 'All videos from User ',
in youtubegallery.php i have made some modifications to show all videos from the user who have posted and show the username
i made some cosmetic in the template files
i will explain them in some pictures
here you can see where i can show all videos from this user
in this picture abve you can see the username who has posted this videos
and the same for your own username
when i am finish with translating this in german i will made a packe for downloding with all modification what i have
here now the updatet YouTube Video Gallery
this files contains the whole gallery with all modifications what i have made and also including the german lang file
youtubegallery_1_0_0_modified.zip
Can't figure out how to allow Global Mods so they can delete in gallery :(
Right now as far as I can see only Admin can delete...
Darkside2016
clight77 wrote: 14 Apr 2016, 16:39 Can't figure out how to allow Global Mods so they can delete in gallery :(
at this moment there is no option to set group permission
Darkside2016 wrote: 14 Apr 2016, 20:29
Busy with update 1.0.1 and will be solved :wink:
Darkside2016
dmzx wrote: 14 Apr 2016, 20:31
will you use the modifycation what i have made ?
Will check on that.
sgtevmckay
Post by sgtevmckay »
dmzx wrote: 14 Apr 2016, 20:49Will check on that.
Ooh OOH! <Kid in a Candy Shop>
Consideration for my Brainstorm stuff too :ugeek:
:mml: Youtube Videos Gallery :mml:
:thankyou:
sgtevmckay wrote: 14 Apr 2016, 21:07
:thankyou:
Will check on this in next release :wink:
For now see first post for update.
Darkside2016
dmzx wrote: 14 Apr 2016, 23:21
:thankyou:
nice job .... thx
Small update on download :thumbup:
Darkside2016
It was to easy .....
the wrong user_id was permitted .... so i can see my own videos, but another user see them not
This is user KillmeSoft and has no Videos. Ther is missing the username from this user
the same is here. you can see KillmeSoft and when i klick on " Show all " the user_id from KillmeSoft will be permited
Darkside2016 wrote: 14 Apr 2016, 23:59 it was to easy .....
dmzx wrote: 14 Apr 2016, 23:51 Small update on download :thumbup:
Download again
Darkside2016
dmzx wrote: 15 Apr 2016, 00:01
Download again
KillmeSoft has no videos uploadet and the username does not show from this user
do you speak german ? so we could talk in TS over this
No do not speak German but did you download the file again?
I did a small update on the download.
