3.2 & 3.3 Extensions Database 3.2 / 3.3 ⇒ Ultimate Points Extension
Re: Ultimate Points Extension
I see this in the "donate points" option with the new phpBB 3.2.2
xvi
Is it possible to be integrated with top five ext?
Posey
I'm guessing you want to show Top Points users (etc) in the Top 5 (Doesn't help if you don't specify anything and leave us guessing ... )? You'll have to ask the author of that extension to integrate it.
''I'm pretty sure there's a lot more to life than being really, really, ridiculously good looking.
And I plan on finding out what that is.''
posey
posey
xvi
Yes, that's exactly what I want. Showing top points users in the top 5 ext.Posey wrote: 17 Jan 2018, 01:44 I'm guessing you want to show Top Points users (etc) in the Top 5 (Doesn't help if you don't specify anything and leave us guessing ... )? You'll have to ask the author of that extension to integrate it.
kaspir
Suggestion for next patch: To display the current lottery jackpot total on index page, along with 'Buy Tickets' hyperlink, inside statistics block.
One addition in /event/listener.php
Template changes in, /template/event/index_body_block_stats_append.html
Example shot:
edit: forgot the '{LOTTERY_PURCHASE_TICKETS}'
edit2: removed <span> around {JACKPOT}, i use a custom templates & classes, but its unnecessary for this post.
'L_PREVIOUS_WINNER' => sprintf($this->user->lang['LOTTERY_WINNER_INDEX'], $username_colored),Add after Add these lines on a new blank line after the preceding line(s) to find
'JACKPOT' => $points_values['lottery_jackpot'],Template changes in, /template/event/index_body_block_stats_append.html
<!-- IF S_DISPLAY_LOTTERY -->{LOTTERY_TIME} • {L_PREVIOUS_WINNER}<!-- ENDIF -->Replace with Replace the preceding lines with the following
<!-- IF S_DISPLAY_LOTTERY --><strong>{L_LOTTERY_JACKPOT}{L_COLON}</strong> {JACKPOT} • <strong><a href="{BOARD_URL}ultimatepoints?mode=lottery" title="{LOTTERY_PURCHASE_TICKETS}">{LOTTERY_TIME}</a></strong> • {L_PREVIOUS_WINNER}<!-- ENDIF -->
Check out phpBB contributions & extension downloads.
Robbie626
Thank you for this updated extension! This was my favorite mod on phpBB 3.0.x, but after the 3.1.x branch, I left phpBB completely. Kudos for you guys developing the best extensions!
lichang422
Sorry , When I install and enable it , It will be shown "HTTP ERROR 500"
How could i solve it ??
Version 1.1.8
phpbb3 3.2.2
Version 1.1.8
phpbb3 3.2.2
Robbie626
Have you try contacting your hosting provider what could have caused the issue? Usually, 500 error codes are errors regarding the website's server.lichang422 wrote: 21 Jan 2018, 16:22 Sorry , When I install and enable it , It will be shown "HTTP ERROR 500"
Version 1.1.8
phpbb3 3.2.2
lichang422
I am the hosting administrator ,and I make a server in my personal PC ,Robbie626 wrote: 23 Jan 2018, 07:34Have you try contacting your hosting provider what could have caused the issue? Usually, 500 error codes are errors regarding the website's server.lichang422 wrote: 21 Jan 2018, 16:22 Sorry , When I install and enable it , It will be shown "HTTP ERROR 500"
Version 1.1.8
phpbb3 3.2.2
Original my phpBB running is OK.
But when I try to "enable" the MOD ,
It show "HTTP ERROR 500"
And the screen turn to like below.
Any button I select always show "HTTP ERROR 500"
Venatus Vinco
Hello error with installation on 3.2.1, do I need to upgrade to 3.2.2 or is there another problem?
Thanks.
EDIT: Fixed it, older version of Mod.
VV
Thanks.
VV
Venatus Vinco
New question.
I have the transfer option enabled and ticked the option to include a note with a transfer...however, there is no space to include a not when sending a transfer.
Is this a bug or do I need to enable something else?
Thanks.
EDIT: Fixed. It was a permissions issue.
VV
Thanks.
VV
eunaumtenhoid
Some new features would be interesting:
- pay paver view forum
- group option, so that users of certain groups earn more points than the default setting of the ext or that they pay more for something
- option to only be able to donate or receive a donation only if you have a X number of points for more or less (example: you can only receive donation who has 100 points or less or can only donate 1000 points or more)
- integration with some extensions ??
- a store extension for UP, to buy digital things from the forum, like: change user name, access to some group ...
- when deactivating an option (e.g. bank) it is not shown in the ucp
Venatus Vinco
Points was working great on my test site...now it is giving 5 points per post even with all awards set to 0.
Is there something hidden somewhere?
VV
EDIT: Found it, individual forum settings needed changing.
VV
WildestDrake
When I tried to enable the extension after upgrading to 3.2 from 3.1.9
I got an SQL error.
I got an SQL error.
SQL ERROR [ mysqli ]
Duplicate entry 'transfer_enable' for key 'PRIMARY' [1062]
SQL
INSERT INTO phpbb_points_config (config_name, config_value) VALUES ('transfer_enable', '1'), ('transfer_pm_enable', '1'), ('comments_enable', '1'), ('logs_enable', '1'), ('images_topic_enable', '1'), ('images_memberlist_enable', '1'), ('lottery_enable', '1'), ('bank_enable', '1'), ('robbery_enable', '1'), ('points_disablemsg', 'Ultimate Points is currently disabled!'), ('stats_enable', '1'), ('lottery_multi_ticket_enable', '1'), ('robbery_notify', '1'), ('display_lottery_stats', '1'), ('uplist_enable', '1')
BACKTRACE-
Venatus Vinco
Hello,heyokajan wrote: 06 Dec 2017, 16:29 Good day,
First of all, thanks for the port to 3.2! It works rather well. I just have a question, is there a general log of all transactions being made? This includes transactions to the bank, between users, to the lottery and through the robbery. The only logs I can find can only be viewed by the user itself but not by the staff.
Thanks in advance.
I did not see a reply to this question...is there an answer? A public log of all transactions or at least one for moderators or admin.
VV
