3.1.x Extensions Database 3.1 / 3.2Top Stats
Null
Re: Top Stats
Post by Null »
What will be the official answer/solution for that?
Re: Top Stats
Null wrote:What will be the official answer/solution for that?
Next update it will be Posts in the extension.
Null
Re: Top Stats
Post by Null »
Standard in phpbb3 is "Replies", take a look:
This should be better to keep this standard in mind.
Re: Top Stats
Standard is replies also the original 3.0.X version was also replies.
After all it is showing you how many replies to the topic not posts as a reply is different from a post.
Null
Re: Top Stats
Post by Null »
So, counter is wrong. Should be subtracted from 1.
RazKaziRo
    Windows XP Chrome
Re: Top Stats
Post by RazKaziRo »
Error from my side:
enable it from its settings
SQL ERROR [ mysql4 ]
Duplicate entry 'tsrat_enable' for key 'PRIMARY' [1062]
SQL
INSERT INTO shg_config (config_name, config_value, is_dynamic) VALUES ('tsrat_enable', 1, 0)
BACKTRACE
FILE: (not given by php)
LINE: (not given by php)
CALL: msg_handler()
LINE: 855
CALL: trigger_error()
FILE: [ROOT]/phpbb/db/driver/mysql.php
LINE: 181
LINE: 329
CALL: phpbb\db\driver\mysql->sql_query()
FILE: [ROOT]/phpbb/config/db.php
LINE: 161
CALL: phpbb\db\driver\factory->sql_query()
LINE: 122
CALL: phpbb\config\db->set_atomic()
FILE: [ROOT]/ext/dmzx/topstats/acp/topstats_module.php
LINE: 34
CALL: phpbb\config\db->set()
LINE: 674
CALL: dmzx\topstats\acp\topstats_module->main()
FILE: [ROOT]/adm/index.php
LINE: 81
CALL: p_master->load_active()
Re: Top Stats
RazKaziRo wrote: 18 Jan 2016, 09:38 Error from my side:
SQL
BACKTRACE
CALL: msg_handler()
LINE: 855
LINE: 181
LINE: 329
LINE: 161
LINE: 122
LINE: 34
LINE: 674
LINE: 81
Looks like there are some database leftover in your db tsrat_enable did you delete all ?
RazKaziRo
Re: Top Stats
Post by RazKaziRo »
dmzx wrote: 18 Jan 2016, 17:39
SQL
BACKTRACE
CALL: msg_handler()
LINE: 855
LINE: 181
LINE: 329
LINE: 161
LINE: 122
LINE: 34
LINE: 674
LINE: 81
I was able to set it again but i think i need little help with the css modification if in enable jquary scroll its messed up:
rohde
Re: Top Stats
Post by rohde »
I have the same problem
how to fix?
dmzx wrote: 21 Mar 2015, 08:31 Got still this on the low resolution
killfrenzy
Re: Top Stats
Post by killfrenzy »
Guys help me to fix this after activating this top stat in my extension error was appeared in the top of my forum like
[phpBB Debug] PHP Warning: in file [ROOT]/ext/dmzx/topstats/event/listener.php on line 270: Division by zero
Also see the attachment. Thanks for the help.
Androidcribs.com
Androidcribs
Re: Top Stats
killfrenzy wrote: 01 Mar 2016, 15:27 Guys help me to fix this after activating this top stat in my extension error was appeared in the top of my forum like
Are there any posts in your forum?
Null
Re: Top Stats
Post by Null »
There is a formatting error in "we_universal" style:
rohde
Re: Top Stats
Post by rohde »
How can i responsive ???
Fast_Eddie
Re: Top Stats
Post by Fast_Eddie »
I recently switched to a new style/skin for the board (( ShadowGlow ))
And the scrolling active topics went from 3 lines to 2. Even though it's most likely a issue with the style I'm hoping someone here might have a quick fix for this?
:beers: Retirement 2024!
Fast_Eddie
Re: Top Stats
Fast_Eddie wrote: 01 May 2016, 15:23 I recently switched to a new style/skin for the board (( ShadowGlow ))
As a temporary fix I have the j-scroll disabled and have active topics in a list format. But would you happen to have a idea on how to get those 3 slots back in the scroll? :question:
