3.2 & 3.3 Extensions Database 3.2 / 3.3 ⇒ Image Upload
killfrenzy
Re: Image Upload
Ive checked the ftp file ext/dmzx/imageupload/files the permission is set in 600 then I've changed to 644 then the image shows. How to set it automatically? Or I've something I missed in this extension?
- Androidcribs.com
- Androidcribs
Re: Image Upload
How did you upload the extension with upload extension or ftp?killfrenzy wrote: 12 Feb 2017, 05:51 Ive checked the ftp file ext/dmzx/imageupload/files the permission is set in 600 then I've changed to 644 then the image shows. How to set it automatically? Or I've something I missed in this extension?
Folder must be indeed 0644, all files will be automatic cmod 0644 when you upload them.
see for ref:
https://github.com/dmzx/Image-Upload/bl ... #L210-L211
killfrenzy
Re: Image Upload
I uploaded the extension in my hosting in filemanager.dmzx wrote: 12 Feb 2017, 09:05How did you upload the extension with upload extension or ftp?killfrenzy wrote: 12 Feb 2017, 05:51 Ive checked the ftp file ext/dmzx/imageupload/files the permission is set in 600 then I've changed to 644 then the image shows. How to set it automatically? Or I've something I missed in this extension?
see for ref:
Re: Image Upload
Strange, check with FTP how the cmod is when you upload a folder.
Re: Image Upload
This is due to the server settings, I think. Filemanager rights are often different than FTP rights (owner/group).
killfrenzy
Re: Image Upload
I'll try to reupload the extension using File Zilla but still the same problem. When I uploaded file the file is set automatic in 600 perm instead of 644 so that's why image doesn't show.
Re: Image Upload
Why are you messing around with file perms ?? only time you need to touch them is if your hosting your self if you have a paid host then by rights they do all the work before handing you your hosting account.
killfrenzy
Re: Image Upload
So I need to contact them?martin wrote: 12 Feb 2017, 18:09 Why are you messing around with file perms ?? only time you need to touch them is if your hosting your self if you have a paid host then by rights they do all the work before handing you your hosting account.
Re: Image Upload
I'm not saying yes or no but you should not be setting file perms.
spinecki
Re: Image Upload
Same problem here. After the upload permissions are set to 0600...
Re: Image Upload
Upload one picture . See error.
permission all yes, phpbb 3.1.10
[ Post made via Android ]
Re: Image Upload
Could anyone help me?
Re: Image Upload
Pm me a site link and test account with access to acp your not going to get much help with just images posted.
DKBjorn
- Translators
Re: Image Upload
Are there plan for make multiple image upload....?
Is it diffficult to implent...?
spinecki
Re: Image Upload
I got the same error in acp. It's permissions related error. If you change chmod (manually) to 0644, error is gone.jan_2017 wrote: 15 Feb 2017, 13:04 Upload one picture . See error.
[ Post made via Android ]![]()
